Fingers crossed - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By onewizard
post #1 of 3 (permalink) Old 08-09-2017, 05:55 PM Thread Starter
skullroses's Avatar
Fingers crossed
When I decide to go full throttle bike revs but won't speed up. New clutch cable and oil/filter change soon. I really hope I don't have clutch damage... 09 with 15k miles.
skullroses is offline
post #2 of 3 (permalink) Old 08-09-2017, 06:55 PM
Check at Footbrake side
You need to check the clutch slack at the foot brake side, there should be about 1/16 of a inch free play at the lever above the foot brake , a common problem on the MK-1 was a pinched clutch cable on the right side just as it passes the gas tank mount. There are 2 adjustments, one is by the throttle cam and the second at the clutch handle / lever , the handle is for fine adjustments the one covered with a rubber boot by the throttle cam is for coarse adjustments. You should be able to slightly pull in the clutch and observe the travel both pullong and releasing, either the cable is pinched and or your adjustment is wrong.Riding a bike with a slipping clutch is almost a certain disaster waiting to happen.
skullroses likes this.
post #3 of 3 (permalink) Old 08-09-2017, 07:30 PM Thread Starter
skullroses's Avatar
I will definitely check that out. Thank you...
