Will a GPS mounted on the instrument cluster cowling die by vibration? - Kawasaki Versys Forum
Like Tree4Likes
  • 1 Post By twowheels
  • 1 Post By silviefox
  • 1 Post By fasteddiecopeman
  • 1 Post By Fastoman
post #1 of 15 (permalink) Old 05-23-2017, 10:37 AM Thread Starter
GoodMoGo's Avatar
Question Will a GPS mounted on the instrument cluster cowling die by vibration?
I want to fabricate a mount that will be attached to the instrument panel cowling and with brackets extending above the instrument dial to hold the actual GPS (Nuvi 57LM).
The bracket immediately attached to the cowling will have a hard foam/soft rubber spacer between it and the plastic cowling itself (the consistency of a pencil eraser) to alleviate any vibration.
I have read many posts stating that area has a lot more vibration than other common mounting points like the handlebars or bar clamps.riser, etc. Some posts hint that it will kill/has killed electronic equipment.
Has any one has experienced equipment failure that they can directly connect to the vibration issue?
Any other thoughts, other than telling me to mount it somewhere else? The alternative is to mount it to the windshield, but I use 2 - a touring and the shorty.
Tks All!!
GoodMoGo is offline
post #2 of 15 (permalink) Old 05-23-2017, 10:47 AM
Yes, I find the micro USB connection a lot of devices use to power them, is very susceptible to fail or have intermittent power, with vibration. I have had two GPS's fail from this issue. On was a Garmin Nuvi.
Lately I have been using my phone instead, in an X Mount that uses rubber holders, and have not had this issue so far, although I need to tape the USB plug to the phone to keep it from falling out with vibration.
GoodMoGo likes this.
post #3 of 15 (permalink) Old 05-23-2017, 11:12 AM
i have a first gen and my phone/gps mount is on a brace i made that goes on the windshield mount (just a peace of perforated sheet metal that goes across the two mounts) has a bit of vibration but ive never had my phone or gps move and i can still easily read it and poke the screen to change settings with gloves still on.......so its not moving that much
post #4 of 15 (permalink) Old 05-23-2017, 07:04 PM
SO FAR - my Nuvi550 shakes like 'heck', but still keeps on tickin'....
post #5 of 15 (permalink) Old 05-23-2017, 08:42 PM
Speedy makes GPS mount bracket for Versys and I have been using since 09.
weljo2001 likes this.
Fastoman is online now
post #6 of 15 (permalink) Old 05-23-2017, 08:54 PM
Ditto.....
IMG_0780 by weljo2001, on Flickr
P1010559 by weljo2001, on Flickr
post #7 of 15 (permalink) Old 05-24-2017, 12:48 PM
Gen 2 only info:
Speedy doesn't make a mount for gen2 above the dash, but Touratech does (https://touratech-usa.com/Motorcycle-GPS-Adapters?a=548) as does a Thailand manufacturer (look for Joey Rocket Films post Zombie Apocalypse), both of which mount in the windscreen holes.
I mounted a RAM ball on the plastic shroud under the windscreen, reinforced on the back with epoxy, matting and a steel fender washer - but it still shook like crap making me worry I'd break it. You could, in theory, add some Velcro along the bottom to better isolate it, and I might try that with some foam rubber - squish it into the foam and tighten the RAM arm. I have a nuvi 2595, not the bike-specific zumo.
I do have a bar-mount RAM cradle, and the device seems to be fine after about 4,000 miles of which about 1,000 is off road and bumpy. If it dies, there's plenty of used car GPS. Zumo still pretty spendy, even used.
Anybody got any other ways of mounting GPS above the instruments on gen 2?
PHX_Joe is offline
post #8 of 15 (permalink) Old 05-24-2017, 09:51 PM Thread Starter
GoodMoGo's Avatar
@weljo2001
Thanks for the pics!!
GoodMoGo is offline
post #9 of 15 (permalink) Old 05-24-2017, 09:57 PM Thread Starter
GoodMoGo's Avatar
@PHX_Joe
Thanks for the info. I had come across those TOURATECHs but I'll keep tankbagging it rather than give someone $90+ for a piece of metal.
I might reconsider being so cheap if my fabrication makes me loose a couple of Garmins (I bought a used one from Craigslist for $40) for the bikes. And I pair it with a portable battery bank. Not sure how long it powers the 5" Nuvi 55LM. I rode for about 3 hours, then forgot it on, in the tank bag, for another 12 - 14 hours. Was still powered and looking for a satellite signal (not sure how much that affects battery consumption).
I'll try to document the fabrication and its results (if good) and post back.
GoodMoGo is offline
post #10 of 15 (permalink) Old 06-01-2017, 07:08 PM
Here's my setup, using a Moto Werk generic GPS mount. It's now almost five years old and the GPS is still going strong.
post #11 of 15 (permalink) Old 06-02-2017, 12:39 AM
JaGrab3's Avatar
Nice, can U take a foto from back side, to see how it looks like.?
Wysłane z mojego SM-A500FU przy użyciu Tapatalka
BMW F650 -> Versys 650 '97
JaGrab3 is offline
post #12 of 15 (permalink) Old 06-02-2017, 06:27 AM
Thaylin's Avatar
My friends Cell Phone mounted in the RAM Mount suffered vibration damage. Now the LG phone's speaker always has a low hum and the rear camera is toast. Front camera still works so all he can take are selfies.. My original Garmin ETREX died from vibration, and my 2 year old Garmin Nuvi has frozen, while in use, and needed a full reset.
I ride to get lost and find my way back.
Thaylin is offline
post #13 of 15 (permalink) Old 06-02-2017, 12:43 PM
I have killed a few gps over the years on diferent motorcycles
2 old etrex
3 car model nuvis
my current gps a zumo 590 is holding up well so far
Motojunkee is offline
post #14 of 15 (permalink) Old 06-02-2017, 01:32 PM
I could not get my Garmin nuvi's to work reliably on a motorcycle. The vibration always caused problems with the USB power connection. This happened on two different bikes, on two different mounts (garmin cradle mount and a RAM X-mount). I now use a Zumo and have no issues. I have my zumo mounted above the instrument cluster (Gen 3) on an sw-motech mount.
zirconx is offline
post #15 of 15 (permalink) Old 06-02-2017, 05:39 PM
Here's a pic of the back of my Garmin Nuvi550 mounted on my Gen 3.
