Sparkbright install - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By AlaskaJeff
post #1 of 6 (permalink) Old 05-18-2017, 12:15 AM Thread Starter
Sparkbright install
Hey all,
I'm very new to electrical systems and have some questions regarding the install of my eclipse8 voltage meter.
Today I installed Kawasaki's relay and hardwired an aftermarket USB charger to the system. (I plan to solder and heat shrink the connections soon).
Andrew, the creator of sparkbright, said I could connect the voltage meter directly to the battery. But I feel like there is an easier/more efficient way to wire this thing in.
Any recommendations?
Cheers!
Hupp92 is offline
post #2 of 6 (permalink) Old 05-18-2017, 12:45 AM
Product & HowTo Info | | | AMMETER | AutoZone.com
How you can open the Link- good luck
post #3 of 6 (permalink) Old 05-18-2017, 02:46 AM
Fastoman, I am pretty decent with electrical stuff, and THAT link is WAY TOO CONFUSING!! My suggestion :There should be an unused plug/connector under the radiator side cover on the left of the bike. Get a muntimeter and find the terminals that are for ground and 12 volts and tap into them to run your volt meter. That is what I did. I used one that is energized when the ignition is on.
chadams66 likes this.
post #4 of 6 (permalink) Old 05-18-2017, 08:00 AM
That's the way I did mine. Best I remember, there were 3 wires with bullet connector under the tank on the left side of the bike. 2 were ground, and one was hot only with ignition on. I used these wires for the usb port that is built into my phone holder.
Skypilot 69 is offline
post #5 of 6 (permalink) Old 05-18-2017, 12:49 PM
Originally Posted by Hupp92 View Post
...Any recommendations?
Cheers!
As a few others mentioned - just use ANY wire that is only HOT when the ignition is ON, and a ground. I used the DRL wires on mine. (Daytime Running Lights.)
post #6 of 6 (permalink) Old 05-18-2017, 05:30 PM
chadams66's Avatar
that's what I did...works great...I love that green color as I'm riding around...
chadams66 is offline
