installed DENALI DM lights on my Gen 3 - Kawasaki Versys Forum
Like Tree5Likes
  • 4 Post By fasteddiecopeman
  • 1 Post By fasteddiecopeman
post #1 of 10 (permalink) Old 05-09-2017, 06:19 PM Thread Starter
I bought a set of DENALI DM lights from an inmate here, c/w the SW-Motech kit to mount them, awhile back.
Weather's been rather "iffy" here, so I started the 'install' yesterday. Right away it became evident that mounting them onto my SW-Motech engine guards would NOT work as long as I wanted them protected from a fall, so I looked around my shop for ideas.
When I got my Polaris R/R from onewizard he'd left the Polaris bracket attached to it, in case I needed it.
I took a look, then back at my SW-Motech engine guards, and thought that I could cut two pieces out of that bracket (already have a bit of a 'curve' to use), then weld them onto the aprox. 2" spacers that go behind the guards, so I cut two pieces off.
A bit of work w/ a reciprocating saw, some grinding, and - VOILA - the two brackets were pretty close to identical.
Wire-brushed the paint where the welds would be:
and then welded the pieces together.
Did a bit more "wire-brushing" and got them clean, ready for paint.
Did some "rattle-canning" and ended up w/ this:
Here they are, installed but w/ the wiring just ready for finishing.
Then I spent about three (or FOUR...) hours finalizing WHERE to put the wiring so it's out-of-the-way, but accessible. The relay, as well as the attachments to + and - power are under the seat area, while I put the ON/OFF switch near the left grip. I'm using the running lights to 'trigger' the relay, so they are AVAILABLE when the ignition is ON, and here's a view of the lights ON.
They're pretty bright, so it should help me to be more visible (as well as help when I ride after dark).
post #2 of 10 (permalink) Old 05-10-2017, 10:50 AM
Nice job, Mr. C. You should be able to ignite shrubbery at 100 meters with that light intensity!!
post #3 of 10 (permalink) Old 05-10-2017, 11:01 AM
BLACK DOG's Avatar
Got those little demons 4 years ago & have been really happy with them.
At night every reflective marker all the way to the horizon is lit.
BLACK DOG is offline
post #4 of 10 (permalink) Old 05-10-2017, 03:06 PM
Light up markers all the way to the horizon, eh? Do they wrinkle up as you close on them?
post #5 of 10 (permalink) Old 05-10-2017, 06:58 PM
quexpress's Avatar
Excellent set-up!
I will certainly clone your idea later on! Thanks for posting!
I still have a full deck.
I just shuffle slower.
quexpress is offline
post #6 of 10 (permalink) Old 05-10-2017, 11:31 PM
bigaussie's Avatar
I like what you have done, other than "I'm using the running lights to 'trigger' the relay, so they are AVAILABLE when the ignition is ON".
I used to have my accessories (via a Fuzeblock) trigger by the running lights.
I then realized they were putting quite a load on the electricals.
I now have the trigger on the low beam headlight so they don't come on till the bike is running.
Cheers
Alan
bigaussie is offline
post #7 of 10 (permalink) Old 05-11-2017, 12:51 AM
Nicely done
consider a separate switch for Aux lights, will save on current drain.
post #8 of 10 (permalink) Old 05-11-2017, 12:30 PM Thread Starter
Originally Posted by bigaussie View Post
...I used to have my accessories (via a Fuzeblock) trigger by the running lights. I then realized they were putting quite a load on the electricals. I now have the trigger on the low beam headlight so they don't come on till the bike is running....
...consider a separate switch for Aux lights, will save on current drain.
Thanks BOTH of you, but I beat you to it!
I installed the DENALI switch (came w/ the lights) so that I can turn the lights OFF or ON, and they stay at that setting even after the ignition OFF, ON sequence, so I'm not worried about current drain. Here's a pic of it, but I haven't finalized WHERE it will 'end-up', which will TRY to explain the 'electricians tape' holding it. I went out last night to "align" the lights, but failed (NOT very dark at 2100 hrs here!), so I plan to try again in the garage....
I DID realize tho', that there's a pretty BRIGHT reflection off the edges of the front-fork amber-reflectors (comes up just between the gas-tank and the cowling "stuff"), so I'll be removing them and putting reflective tape onto the fork-lowers.
AngryGazebo likes this.
post #9 of 10 (permalink) Old 05-11-2017, 01:51 PM
Naitramde's Avatar
I like it. Very nice fab work, makes it look like a factory install.
2011 Versys 650
Even a fool is thought wise if he keeps silent... Proverbs 17:28
Naitramde is offline
post #10 of 10 (permalink) Old 05-19-2017, 10:51 AM
Lours_Polaire's Avatar
Nice Eddie
Very nice !
LOP
Lours_Polaire is offline
