2014 gas cap corroded shut. - Kawasaki Versys Forum
 3Likes
  • 2 Post By frozenhawaiian
  • 1 Post By invader
post #1 of 20 (permalink) Old 04-11-2017, 12:42 PM Thread Starter
frozenhawaiian's Avatar
here's an odd one for you guys, I have 2014 versys, I filled the tank up with fresh gas and stabilizer at the end of last season. I just finished out that tank and now the gas cap appear to be tuck shut, it was a touch stiff before but moved easily enough, now I can't get it to budge. I've tried pushing down and turning to the point that I can feel the key start to flex, and idea on how to get this thing unstuck?
frozenhawaiian is offline
post #2 of 20 (permalink) Old 04-11-2017, 02:14 PM
It's a bit late now but have you tried lubing it with penetrating oil? Careful with your paint.
post #3 of 20 (permalink) Old 04-11-2017, 02:44 PM
I used a little WD-40 then got these for the bikes....No need for a key.
IMG_0017 by weljo2001, on Flickr
P1010532 by weljo2001, on Flickr
post #4 of 20 (permalink) Old 04-11-2017, 03:22 PM
kenr74's Avatar
+1 for the non locking cap. Every time I had to unlock my stock cap on my 09 I was afraid of snapping that key off.
Maybe get a copy of your key made from a steel blank and give it a shot.
1974 Kawasaki F11
2004 Yamaha WR450 plated
2014 Kawasaki Versys 650
kenr74 is offline
post #5 of 20 (permalink) Old 04-11-2017, 04:00 PM
Had a similar issue. Easy to fix though with a couple of squirts of WD-40 in the key hole.
post #6 of 20 (permalink) Old 04-11-2017, 10:32 PM Thread Starter
wd-40 and an overnight soak hasn't fixed it, neither did a soak with kroil oil.
post #7 of 20 (permalink) Old 04-11-2017, 11:40 PM
pb blaster?
also is it still on the bike or have you removed the cap assembly from the tank?
post #8 of 20 (permalink) Old 04-12-2017, 01:25 AM
Yeah just unbolt it from the tank, then you'll see if you can fix it... If not, you could then replace it.
post #9 of 20 (permalink) Old 04-12-2017, 08:44 AM
BLACK DOG's Avatar
I may be wrong....again, but I thought that locking tabs would remain locked into the tank neck even if the outer ring screws are removed.
BLACK DOG is online now
post #10 of 20 (permalink) Old 04-12-2017, 09:09 AM
CyclopsRider's Avatar
Mine was kinda sticky from sitting a lot when I bought it last year. I had a can of liquid wrench lock lubricant/de-icer sitting on my shelf and spraying some of that into the keyhole freed it up smoothly and it's still good. I love the stuff. I had a door lock cylinder completely seize on my work crown vic and spraying that stuff in there actually freed it up. I've had good luck with it when it comes to lock cylinders of all types.
2009 Blue Versys
CyclopsRider is offline
post #11 of 20 (permalink) Old 04-12-2017, 11:11 AM
RMS
The metal that Kaw uses for the cap is crap, I use a wire brush to clean off the corrosion the oil it with 90wt gear oil very often
My cap was stuck closed at one time , and I bent a key trying to open it, but it finally gave in and opened
I place a rag over the tank opening wile cleaning and oiling and I oil the clamps and housing under the lid
RMS is offline
post #12 of 20 (permalink) Old 04-12-2017, 07:08 PM
The cap on my '08 got very stiff last winter. I sprayed some graphite into it, then followed that w/ a GOOD squirt of WD40. Opened EASILY then, so I blew compressed air thru the OPENED cap keyhole, blowing the extra 'stuff' out.
Worked fine after that.
post #13 of 20 (permalink) Old 04-12-2017, 07:19 PM
I believe your right. If i remember correctly when i was taking mine off the 09 V-650 i had to use the key even after taking all the bolts off the gas cap assy...
post #14 of 20 (permalink) Old 04-12-2017, 08:57 PM
BLACK DOG's Avatar
Angry
Yep...have my oem sitting on my workbench, and if you can't turn the key you are in a bad spot. The locking tabs are in to the filler neck.
post #15 of 20 (permalink) Old 04-12-2017, 09:24 PM
Thumbs up
"So I took the screws off the cap, and yeah it wasn't unlocked so I pried and pulled, stuck a screw driver in there and wala it came right off no damage. So even if the cap is locked you still can remove the cap."
Zx10 With stuck Fuel Cap Ugh!! - ZX Forums
post #16 of 20 (permalink) Old 04-14-2017, 06:19 PM Thread Starter
FINALLY got it loose!!!! 18 hours of free all soaking got it loose!
turn8a and weljo2001 like this.
post #17 of 20 (permalink) Old 04-15-2017, 02:56 PM
GOOD for you!
post #18 of 20 (permalink) Old 04-15-2017, 07:59 PM
BLACK DOG's Avatar
Sometimes it's hard to be patient. Glad you got thru without going gorilla on it.
post #19 of 20 (permalink) Old 04-15-2017, 08:03 PM
That is weird. My 15 650 lt is corroding very bad as well. Bike has never seen rain and is stored in a heated garage year round. 93 octane and stabilizer as well. Wonder what it is
Corvette96 is offline
post #20 of 20 (permalink) Old 04-15-2017, 08:11 PM
Such quality problems are manifesting themselves more frequently since they're being made in Thailand (2011+) instead of in Japan like my 2007... It is quite deplorable.
quexpress likes this.
