Clutch jolts on Versys 1000 - Kawasaki Versys Forum
Like Tree4Likes
  • 3 Post By Duffy
  • 1 Post By saddlebag
post #1 of 7 (permalink) Old 03-26-2017, 06:09 AM Thread Starter
Kurkess's Avatar
Hi
I'm enjoying my Versys 1000 (model 2013'ish).
I have got an issue though - whenever I start the bike in first gear the bike/clutch jolts into motion. This makes it a little hard to control the bike from standstill. It's less of a problem if I rev the gas somewhat, but think I should be able to finetune my clutch action to move slowly without having the bike jump all over the place. Any idea what could be the problem?
Jakob
Jakob
Denmark
"Remember your moms and dads when you ride. When you take care of yourselves, you are honoring them with your most precious gift... your lives. It is not in the scheme of life for your child to pass before you do. Be sure that you do all that you can to ensure that you honor that truth."
Kurkess is offline
post #2 of 7 (permalink) Old 03-26-2017, 07:23 AM
Tomasama's Avatar
Yup you answered your own question. Adjust the clutch lever. it's too short.
You shouldn't feel the clutch start to grab until the last knuckles on your fingers start to unfold.
I hope that sentence makes sense
West coast is best coast!
My motovlog
Tomasama is offline
post #3 of 7 (permalink) Old 03-26-2017, 09:33 AM
After starting, I usually pull-and-release the clutch lever a couple of times before I put it into gear.
post #4 of 7 (permalink) Old 03-26-2017, 10:27 AM
Sometimes the clutch plates will "stick" together due to oil between them. If the adjustment is correct just put it in gear before starting and push it a forward a couple of inches (that breaks the clutch plates loose). Then continue as normal.
onewizard, saddlebag and Kurkess like this.
Duffy is offline
post #5 of 7 (permalink) Old 03-27-2017, 05:14 AM
saddlebag's Avatar
I haven't had this problem with my V1k, but my Warrior's clutch plates would stick whenever it got cold out. It had so much bottom end that sans brakes, the bike would just get underway if in gear with the clutch pulled to the grip.
Once the oil warmed up it was fine.
Duffy likes this.
Science...because we don't figure things out by praying.
saddlebag is offline
post #6 of 7 (permalink) Old 03-27-2017, 09:28 AM
I've had that problem to some degree with every bike I've had except the smaller ones (650 and below). I've never noticed it with the Versys.
Duffy is offline
post #7 of 7 (permalink) Old 06-15-2017, 01:47 AM Thread Starter
Kurkess's Avatar
Had the bike at the shop and they changed the clutch plates. Several of them was almost fusted together.
The clutch run much smoother now - although I still detect some vibration when starting from standstill.
Jakob
Denmark
Kurkess is offline
