Low RPM miss..... - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 08-24-2008, 06:33 PM Thread Starter
Guest
Low RPM miss.....
anyone else expierianced a little miss usually at low rpms, but only when you are at about 10 percent throttle. if you give her some gas it goes away....
myorangecamaro is offline
post #2 of 6 (permalink) Old 08-24-2008, 08:01 PM
golfmuch's Avatar
I had that for a couple days. Bad gas from a station that had recently changed over to Ethanol. Put some seafoam in the tank. It took 2 tank fulls to go away.
golfmuch is offline
post #3 of 6 (permalink) Old 08-25-2008, 01:12 AM
Guest
You missed pointing out a few things about your bike. The fact that you have a power commander 3, titanium two brothers exhaust, bmc air filter, and a custom dyno tune might help a bit with the diagnosis.
The bad gas idea could definitely be valid, but it could be a fuel table that isn't mapped quite right. Did it start before or after your dyno tune?
08 Versys is offline
post #4 of 6 (permalink) Old 08-25-2008, 01:58 AM Thread Starter
Guest
actually it just started about two days ago, i think the ethanol idea may be right paired with the re-mapped bike, i did notice it went away a bit for awhile so it was probably because i put good gas in it, ive just been riding so much latly its been hard to keep track. i took it back and got a new map yesterday becasue he wanted me to bring it back in a week and run it one more time. I did some research over a few beers tonight on gas with ethanol, and is seeming to go hand in hand. good thing it rains so much here that all i can do is sit around and write about it instead of actaully try ideas! ill get you the map tomorrow and you can give it a try
post #5 of 6 (permalink) Old 09-08-2008, 10:31 PM Thread Starter
Guest
ok i found a guy on versys.co.uk whoes having the same problem, with no mods, and a few others were having it too, anybody here had that?
post #6 of 6 (permalink) Old 09-08-2008, 10:57 PM
On the fench Kawette forum as well when it's colder outside... You could check your TPS setting and throttle body vacuum synchronization.
Similar Threads
Bikes that you miss?? Enemy Zero Other Motorcycle Make and Model Discussion 62 03-13-2009 12:29 AM
How much will I miss ABS on the Versys? Bob Technical Discussion - V-650 5 05-30-2008 12:31 PM
