Aux lights dimmer switch - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By kuri77
post #1 of 7 (permalink) Old 09-07-2016, 02:54 PM Thread Starter
I have 6 amp total aux led lights. Anyone recommending a dimmer switch for them? As in you bought it and it's working fine so that if I get one I can pick your brain if I run into snags. The PO had them wired into the high beams but they are so bright prevents my wanting to use them for daylight awareness. Rarely ride at night so basically useless to me at present. I did tip them down and will experiment with that some more if no dimmer workable.
kuri77 is offline
post #2 of 7 (permalink) Old 09-07-2016, 04:13 PM
Another idea would be to use your existing light mounts and also mount daytime running light bullets (cheap most places) LEDs connected to your low beam.
post #3 of 7 (permalink) Old 09-07-2016, 05:33 PM Thread Starter
Good idea and may have to consider that if there are no other solutions, thanks
kuri77 is offline
post #4 of 7 (permalink) Old 09-07-2016, 06:22 PM
I use a Skene IQ-170, which has been superseded by this: Skene Design Motorcycle Visibility Lights I like it.
....ride like the one-eyed Jack of Diamonds with the Devil close behind...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility, it's right. If it disturbs you, it's wrong until either the machine or your mind is changed."
-Robert M. Pirsig
bcalan is offline
post #5 of 7 (permalink) Old 09-07-2016, 10:45 PM Thread Starter
That looks like just the ticket, will look into it. Thanks
kuri77 is offline
post #6 of 7 (permalink) Old 09-18-2016, 05:50 PM Thread Starter
Went riding with my buddy and after I tilted the aux lines down he said wasn't annoying at all. So came home yesterday in the dark and no one flashed their lights at me so I guess I'll just keep it that way. Rarely ride at night so riding with high beams and aux in daytime shouldn't be a problem for other drivers and makes me way more visible.
quexpress likes this.
kuri77 is offline
post #7 of 7 (permalink) Old 09-18-2016, 08:35 PM
quexpress's Avatar
Well done!
Note: Motolight recommends to set them to a 3 degree downward slant. On my previous bike, I have had my auxiliary lights adjusted that way for years without any dimmers, etc. .... and no one complained (fellow riders, oncoming vehicles, etc.). My Versys currently has 2 auxiliary LED lights (slanted 3 degrees downward) plus a LED light bar. A second pair of auxiliary LED lights will be added to the front this winter. Conspicuity is my main goal.
I still have a full deck.
I just shuffle slower.
quexpress is offline
