First Oil Change On The V 1000 (600 miles) - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By outdoorgb
post #1 of 8 (permalink) Old 07-28-2016, 05:14 PM Thread Starter
Well its hot as hell today but wanted to get the first oil change done. One cover to remove 1-4mm hex bolt and 2-6mm hex bolts. Dumped the oil and removed filter. As you can see i stuck a screw driver through the filter and then used a big set of pliers to get the filter off. Drained well. Put in Castrol 10W-40 4T Dino Oil that O'Reillys had for $5.99 a quart. Put the PCS-1 Re-Usable filter that i've been using since 2010 on my 09 Versys then 07 FJR now on the 16 V-1000......
First Oil Change 600 miles by weljo2001, on Flickr
post #2 of 8 (permalink) Old 07-28-2016, 06:21 PM
outdoorgb's Avatar
I did my first a week or so ago....very easy to do. I found mine to take exactly 4qt...same for you?
weljo2001 likes this.
outdoorgb is offline
post #3 of 8 (permalink) Old 07-28-2016, 06:55 PM Thread Starter
Yep, 4 put it right at the top line on the sight glass.
post #4 of 8 (permalink) Old 07-28-2016, 06:56 PM Thread Starter
Just installed the Givi Rack......
Givi Rack by weljo2001, on Flickr
post #5 of 8 (permalink) Old 07-28-2016, 07:42 PM Thread Starter
Put the Givi E-55 Topcase on.
Givi E-55 Topcase by weljo2001, on Flickr
post #6 of 8 (permalink) Old 07-28-2016, 08:12 PM
How's the seat?
post #7 of 8 (permalink) Old 07-28-2016, 08:43 PM Thread Starter
How's the seat?
So much better than the 650's was. Has a slight front slide to it but not bad. Was thinking about the SC kit. But might just leave it alone.
post #8 of 8 (permalink) Old 07-29-2016, 08:36 PM Thread Starter
