Rubber strip on top of radiator??? - Kawasaki Versys Forum
 1Likes
  • 1 Post By bluesman77
post #1 of 5 (permalink) Old 07-24-2016, 07:57 PM Thread Starter
bluesman77's Avatar
I was checking the front tire pressure this evening on my '15 V650 & glanced up at the radiator to see if there was any damage to the cooling fins. I noticed what looked like a gasket laying on top of the radiator as wide as the radiator depth and about as long as its width. The material is similar in thickness & flexibility to an inner tube w/ cutouts for the radiator cap, fan shroud, etc. & was placed prior to the radiator installation because the top mount goes through it. It just lays on top of the radiator like it was used to protect it & doesn't actually fit other than the cap neck & shroud. Any thoughts as to what it is or its purpose???
...I am a Cafe Racer myself, on some days...and nights for that matter...and it is one of my finest addictions...
--- Hunter S. Thompson 1995 ---
2017 Triumph Street Scrambler, 2012 Triumph Thruxton, 2003 Ducati M800Sie, 2001 BMW R1100R-L, 1999 Kawasaki KLR650, 1996 Harley XLH Sportster S, 1972 Yamaha XS-2
bluesman77 is offline
post #2 of 5 (permalink) Old 07-24-2016, 09:05 PM
Rebel13's Avatar
It's a shroud. It helps control the direction and seperation of the hot air from the radiator and cool air to the intake.
Rebel13 is offline
post #3 of 5 (permalink) Old 07-24-2016, 10:01 PM Thread Starter
bluesman77's Avatar
So it's supposed to fill the gap? Mine evidently has fallen down as it just lays on top of the radiator. What holds it in position?
post #4 of 5 (permalink) Old 07-24-2016, 11:27 PM
Rebel13's Avatar
Yes that is right. It sits on top of the radiator and valve cover. If I recall it is held on with two bolts on the valve cover and a clamp on the frame or radiator. I can't recall exactly, I don't have it near me to verify. Above the rubber is the snorkles for the air box, it is meant to keep the hot air away.
Rebel13 is offline
post #5 of 5 (permalink) Old 07-25-2016, 12:09 AM Thread Starter
bluesman77's Avatar
Thanks. I took a flash light and looked around some more and it makes sense. The left-side (looking back at the radiator) had blown up a bit & things looked pretty weird. Again, thanks!
BTW - I like your avatar.
Rebel13 likes this.
