wheel interchangeability - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By Beezerboy
post #1 of 9 (permalink) Old 06-28-2016, 11:42 AM Thread Starter
Beezerboy's Avatar
pretty sure I saw someone post that all years use the same wheels.... that true? I have ABS & it looks like the sensor ring just bolts on with the rotor & no problem. any thoughts? the plan is to have 2 sets of wheels with the 2nd having a more dirt type tire.
the extra rear is most important. I might just run a more aggressive tire on the front all the time. its a strategy that has worked for me other bikes
Beezerboy is offline
post #2 of 9 (permalink) Old 06-28-2016, 11:49 AM
All Kawasaki 650 motorcycles, Versys, Ninja and ER6N have the same wheels
Not sure if ABS and non ABS bikes use same wheels or not.
Sent from my VS985 4G using Tapatalk
post #3 of 9 (permalink) Old 06-28-2016, 04:04 PM
Yes, wheels are the same for ABS and non-ABS bikes. Wheels are shared with 2006 to 2011 ER6 bikes, 2012+ use different wheels.
Süsser Tod is offline
post #4 of 9 (permalink) Old 06-28-2016, 07:27 PM Thread Starter
Beezerboy's Avatar
thanks guys. I just got a late model Ninja wheel with rotor & ABS plate attached off of fleabay... 75 bucks. he shoots.... HE SCORES!
unstable_rider likes this.
post #5 of 9 (permalink) Old 08-09-2016, 12:16 PM
How confident are we that 2009-2010 ER-6n front wheels will work? I'm in need of a front rim and a salvage yard near me has one for an 09 ER-6n available.
Anything else need to be swapped, like the axle, spacers, or bearings?
spacepirates is offline
post #6 of 9 (permalink) Old 08-11-2016, 06:03 AM
Anyone know if ZX-6E rims (circa late 90s-early 2000s) will fit? I've got a set from an EX500 project I abandoned years ago just sitting around collecting dust (at a glance, looks promising). I imagine a few eBay rotors, bearings, coat of paint, and I could have a second set of rims loaded with more off-road friendly rubber.
mentolio is offline
post #7 of 9 (permalink) Old 08-11-2016, 09:47 AM
that is a score, the fronts seem to be stupid expensive on fleabay
Keep it rubber side down and enjoy the ride
Get healthy - Get Fit - Change Your Life
sharkynrk is offline
post #8 of 9 (permalink) Old 08-11-2016, 07:37 PM
yeah, i just bought an 09 ER6n front wheel with tire, without rotors for $175 shipped. I had called half a dozen salvage places, but no one had anything that would fit.
post #9 of 9 (permalink) Old 08-13-2016, 01:52 PM
Confirmed, '09 ER6N wheel works just fine. Took the spacers, rotors, and axle from the stock wheel and put them on the ER6N wheel; all is good.
