2015 kawasaki verys 650 - no power - Kawasaki Versys Forum
Like Tree3Likes
  • 1 Post By Time
  • 1 Post By starky
  • 1 Post By Green Streak
post #1 of 17 (permalink) Old 06-04-2016, 01:40 PM Thread Starter
Hi All
Need some help form the experts. I installed a 12v accessory to my verys 650 (2015) a fortnight back. I used the following:
1. kawasaki OEM relay kit (Item# 99994-0556)
https://www.kawasaki.com/Accessories...0FFF/999940556
2. Bikemaster 12V accessory soket (TC-6613WA)
Amazon.com: BikeMaster 12V/15A Standard Cigarette Lighter Socket for Power Supply TC-6613WA: Automotive
it all worked initially. However it stopped working a couple of days back. I took everything apart to check for losoe wires and used another 12v accessory socket - but still no power.
I realized that i had tried to use a portable air pressure unit a few days back and there was no power then. (did not test the 12v accessory after that).
http://www.amazon.com/Slime-40022-12...ilpage_o03_s00
Wanted to check if there is a fuse or something else i might have blown. Or is the relay gone or i have done some damage to the machine. Everything runs well and there are no warning lights.
I am pretty disappointing and long drives this weekend are out.
Can someone please advise - am completely distraught. Thanks.
starky is offline
post #2 of 17 (permalink) Old 06-04-2016, 02:46 PM
Check your fuses.
post #3 of 17 (permalink) Old 06-04-2016, 02:46 PM
When you put in the relay, it "powers-up" several things (I believe - FOUR). WHICH set of leads did you use?
You can check for 12v at one of the other sets of wires to 'prove' the relay is still functional (or NOT), which can help 'narrow' the search.
post #4 of 17 (permalink) Old 06-04-2016, 03:09 PM Thread Starter
i used the wires after slicing a layer of black tape holding the male-female plugs together and plugged it in the 12v accessory. Reference form post shown below:
http://www.kawasakiversys.com/forums...t-install.html
Is there a fuse i should check for? location?
Are there other outlets powered by the relay i can use to plug in the 12v accessory?
Will the relay blow as easily as that? I had plugged the tire pressure unit when the bike ignition was on but engine was not running.
Sorry complete noob with the bike electricals here.
starky is offline
post #5 of 17 (permalink) Old 06-04-2016, 03:18 PM
TRZ Charlie's Avatar
Check your manual. The fuse locations are shown there.
Cheers,
Charlie
TRZ Charlie is offline
post #6 of 17 (permalink) Old 06-04-2016, 04:28 PM Thread Starter
fusebox 2c (accessory fuses) look fine.
any other advise?
thanks.
starky is offline
post #7 of 17 (permalink) Old 06-04-2016, 04:56 PM
The 2015 accessory wires run off a 5 amp fuse and a 30 amp relay. I suspect your compressor draws more than 5 amps and you blew the fuse. See photo for location. If you want more amps at the 12v outlet, use the accessory wires to trigger a separate relay connected directly to the battery, using an inline fuse.
Edit: Your compressor draws 280 watts. You blew the fuse. Replace.
IAMRA is offline
post #8 of 17 (permalink) Old 06-04-2016, 05:45 PM
Time's Avatar
any other advise?
thanks.
I'd replace the fuse. I have has them look good but be bad. There not that much you know and replacing it might solve the problem.
weljo2001 likes this.
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #9 of 17 (permalink) Old 06-04-2016, 05:46 PM
Ditto....
post #10 of 17 (permalink) Old 06-04-2016, 06:06 PM
Time's Avatar
I have has them
I have HAS them??? should be I have HAD them.
I need to talk to my doctor as I think my meds are off...again.
2012 650 Versys
Time is offline
post #11 of 17 (permalink) Old 06-04-2016, 07:35 PM
need to file that fat finger down a bit
post #12 of 17 (permalink) Old 06-04-2016, 09:56 PM Thread Starter
thanks a ton guys - i replaced the accessory fuse and voila - i got power. The fuse looked okay but the replacement fuse worked.
Gosh i should have done this first - 30 mins wasted along with a pulled lower back muscle trying to pick up the screws from the floor. :-(
starky is offline
post #13 of 17 (permalink) Old 06-04-2016, 09:58 PM
Time's Avatar
Always check the simple things first.
Glad you're back up and running.
2012 650 Versys
Time is offline
post #14 of 17 (permalink) Old 06-05-2016, 01:38 PM
For a quick fix, put battery clips on your air compressor leads. When you need to pump up a tire, just connect straight to the battery. Some compressors, such as mine come with battery clips.
Time likes this.
Green Streak is offline
post #15 of 17 (permalink) Old 06-06-2016, 11:18 AM
IF a fuse doesn't appear to be 'done', I use my multi-meter to check if it's OK. (I also check any APPARENTLY burned-out bulbs the same way.)
post #16 of 17 (permalink) Old 06-06-2016, 12:10 PM
Damn, Why didn't i think of that....
post #17 of 17 (permalink) Old 06-06-2016, 12:59 PM Thread Starter
sometime the simple things leave us stumped...
starky is offline
