brake line routing - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 05-04-2016, 02:16 PM Thread Starter
brake line routing
So I didnt take before pictures cause i like to take risks in life. Real badass over here. Any who, after swapping on the 929 front end and making caliper brackets, the front brake lines seem out of place. Pretty sure due to the brackets the calipers are now lower on the rotors than stock.
How are the stock lines routed and held out of the way of things? Does the hose from the master go on top of the other line or under the other line tht connects both calipers? I have the hose from the master connector to the right caliper at this time.
When bleeding do I bleed the right or left caliper first? (sitting on the bike view).
borjawil is offline
post #2 of 9 (permalink) Old 05-04-2016, 02:37 PM
How are the stock lines routed and held out of the way of things? Does the hose from the master go on top of the other line or under the other line that connects both calipers? I have the hose from the master connector to the right caliper at this time.
When bleeding my front brakes I bled one side, then the other, then back to the original side, then the other. Think I did this 3 or 4 times in total before I got all the air out completely. Get a cheap bleed bottle and be prepared to pour the collected fluid back into the reservoir several times on the brake handle. Those micro bubbles that you have to look very carefully to see will take time and will require pumping lots of fluid through the system. 98% percent of the air comes out quickly but the remaining 2% or so, takes time. Even after you think all the air is out, run a reservoir of fluid through each side, just to see if more air comes out. Don't let the reservoir run dry while doing this or you will have to start over.
The benefit of doing this, along with installing steel braided lines, is a very firm, precise, brake lever feel. I compared my brake feel pull to a new versys on the showroom floor. My brake handle goes from very low resistance to extreme firmness, when the pads touch, with no in between sponginess like the stock bike. With the improved braking force feedback, I feel I can more closely modulate braking force, and in the process brake harder without feeling like I am going to accidentally lock up the front wheel.
post #3 of 9 (permalink) Old 05-04-2016, 02:49 PM
...How are the stock lines routed and held out of the way of things?....
Mine are mounted one-on-top-of-the-other at the master cylinder.
I ran the two lines down then used a zip-tie to hold them near the lower triple-tree, w/ one going to each caliper.
...Does the hose from the master go on top of the other line or under the other line that connects both calipers?....
IF you can - run separate lines to each caliper.
...When bleeding do I bleed the right or left caliper first? (sitting on the bike view).
IF you run two lines, just start w/ the FURTHEST from the master - that'd be the left one.
post #4 of 9 (permalink) Old 05-04-2016, 04:32 PM
post #5 of 9 (permalink) Old 05-04-2016, 04:34 PM
post #6 of 9 (permalink) Old 05-05-2016, 10:09 AM Thread Starter
I do not have two brake lines from the master. Thats why i asked in which position the hose from the master goes - on top of the hose that connects the two caliper or below. Or does it not matter.
borjawil is offline
post #7 of 9 (permalink) Old 05-05-2016, 12:46 PM
On my '15 ABS the line goes to the LEFT caliper, then up-and-OVER-the fender to the right side.
My SERVICE MANUAL does NOT give any instructions on WHICH caliper to do first, but I think I would do the right first, as it's the furthest from the master cylinder....
post #8 of 9 (permalink) Old 05-05-2016, 02:53 PM
Biz
Biz's Avatar
[QUOTE=twowheels;1135010]When bleeding my front brakes I bled one side, then the other, then back to the original side, then the other. Think I did this 3 or 4 times in total before I got all the air out completely. Get a cheap bleed bottle and be prepared to pour the collected fluid back into the reservoir several times on the brake handle. Those micro bubbles that you have to look very carefully to see will take time and will require pumping lots of fluid through the system.
Trust me... Never, Ever put brake fluid that's been pushed out the bleeder back into the master cylinder. You don't want contamination or aerated fluid re-introduced into the system. Brake fluid is cheap, buy a big bottle and use fresh fluid.
Biz is offline
post #9 of 9 (permalink) Old 05-07-2016, 11:31 PM
Originally Posted by Biz View Post
...Trust me... Never, Ever put brake fluid that's been pushed out the bleeder back into the master cylinder. You don't want contamination or aerated fluid re-introduced into the system. Brake fluid is cheap, buy a big bottle and use fresh fluid.
Absolutely correct!
