ZUMO 660 GPS mounted pics please? - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 04-28-2016, 10:40 PM Thread Starter
Glenno's Avatar
Have any of you designed and built your own GPS mount systems? If so please post pictures. I'm working with a ZUMO 660 but any ideas may help? Thanks
Versatile Versys
Glenno is offline
post #2 of 5 (permalink) Old 04-28-2016, 11:13 PM
Okay, not the answer you wanted, but have you seen the SW-Motech anti-vib mount? I'm using the standard Garmin 665 RAM mount. It works but GPS location makes it hard to read part of the instruments and get to the key. I really like the looks of the SW-Motech for the 2015 Versys, but it puts the unit farther away.
RVerde is offline
post #3 of 5 (permalink) Old 04-29-2016, 01:48 PM
I have a Mk3 2015 so there are limited off the shelf options.
For me the big issue has been the degree of vibration. My first attempt was to use the SW-Motech Mount for an iPhone above the binnacle attached to the screen frame. This vibrated so much that I was serious concerned with the phone surviving.
I then attached the 660 by using a RAM ball on the SW-Motech mount with a short arm. A longer arm restricted the lock-to-lock of the handle bars. Even with the RAM arm it still vibrated but was usable.
Now I have bought a Touratech cradle and had a bar welded onto the SW-Motech iPhone mount. The only problem is with the Touratech cradle as there is insufficient gap to get at the Garmin cradle release lever.
My 660 has Cambodian maps produced by a local company for various Aid agencies like the UN and USAID. It has no routing capabilities but is pretty accurate. I cannot use Google maps as I lose cell phone coverage at the most critical points and Google Offline Maps are not supported in Cambodia.
Traveling around Phnom Penh roads it is fine with vibration at around 2,500 to 3,000 rpm which settles out at higher rev ranges. I have yet to try on dirt roads or very bumpy country roads at high speed I will try those out next week...
AdamG is offline
post #4 of 5 (permalink) Old 04-29-2016, 10:00 PM Thread Starter
Glenno's Avatar
Thanks guys. I have some more research to do for sure.
Versatile Versys
Glenno is offline
post #5 of 5 (permalink) Old 04-29-2016, 10:18 PM
You could just replace one of your riser bolts with one of these and use a Ram Mount.....http://www.amazon.com/Ram-Mount-Moto...f_=pd_ybh_a_28
