Adding another brake light to my '15 650LT - Kawasaki Versys Forum
 4Likes
  • 2 Post By IAMRA
  • 1 Post By IAMRA
  • 1 Post By IAMRA
post #1 of 15 (permalink) Old 04-08-2016, 02:07 PM Thread Starter
Originally Posted by Green Streak View Post
I bought the Admore LED kit for the GIVI rear case. I like the idea of not cutting into the original wiring. Where did you obtain the correct connectors for the tail light?
My 2015 uses Sumitomo 3 pin MT .090 connectors. I used these to make a harness for the same reason.
Motorcycle MT .090 Sealed Series - Connector and Terminals
Scroll halfway down the page and find "MT 090-3C
zirconx likes this.
IAMRA is offline
post #2 of 15 (permalink) Old 04-09-2016, 09:40 AM
chid's Avatar
For turn signal on 2009 I had Sumitomo .050 connectors
Not sure yet if 2015 has the same, but I'll check soon.
Versys 2015 Green
chid is offline
post #3 of 15 (permalink) Old 04-23-2016, 02:11 PM
I'm in the process of making an aluminum rack to (occasionally) add to my 'Genuine Kawasaki Rack' that I recently put onto my '15 for just this purpose. The rack mirrors what I had on the GREEN HORNET for carrying the tent, sleeping-bag, etc I carry on long trips such as D2D.
When I got home w/ the 20" x 24" piece and laid it onto the rack, I saw that the stock tail-lights are rather 'hidden', then on removing the aluminum piece and looking AGAIN, discovered that the tail-lights are pretty much hidden w, JUST the Kawi rack on....
Got back on the GREEN HORNET TOO, and 'toodled' down to Princess Auto to see what they had for LED lights. After about 45 minutes comparing them I decided to get this:
then rode by the place where I got the aluminum, and picked up a foot-long piece of aluminum angle, 1" x 1".
I spent half an hour measuring, then determined I could cut it to about the same 9 5/8" as the light,
Next I looked at the wiring diagram, determined that the brake light is powered by a blue/red-trace wire which I 'tapped' into, running the ground to a convenient bolt at the rear of the seat pan area, drilled two 1/4" holes into the Kawi rack lower piece, 'rattle-canned' the aluminum angle black and mounted it to the rear of the Kawi rack.
and here's what it looks like.
Here's w/ running lights
and brakes ON.
FWIW - light cost $25CDN (tax in.); paint, wire, tape, connectors maybe $2; aluminum angle free.
I SUGGEST that you w/ Gen 3s take a GOOD look at your visibility from the rear.
post #4 of 15 (permalink) Old 04-23-2016, 02:37 PM
chid's Avatar
Thanks Ed!
That's a good point, I'm also planning to add something more visible in the back, now that the Givi trunk is in the back.
I'm thinking to put it behind the plate, so it won't block the view of the OEM brake light, but I have to see how
Also, I found this video, the guy is using the same light to give dual intensity, running light and brake: (I didn't try it yet)
dual intensity motorcycle brake/tail light
Versys 2015 Green
chid is offline
post #5 of 15 (permalink) Old 04-24-2016, 12:12 PM
What color wire do you tap into under the seat. I couldn't exactly tell from your photo. I have an LED brake light bar I want to install. It mounts on the lower lisc plate holes.
Todd
White 2015 650 LT
Apple Valley, Minnesota
Squishman is offline
post #6 of 15 (permalink) Old 04-24-2016, 12:26 PM
cuckoo's Avatar
His qoute. "Next I looked at the wiring diagram, determined that the brake light is powered by a blue/red-trace wire which I 'tapped' into, running the ground to a convenient bolt"
cuckoo is offline
post #7 of 15 (permalink) Old 04-24-2016, 12:27 PM
Cool thx.
Todd
White 2015 650 LT
post #8 of 15 (permalink) Old 04-24-2016, 02:31 PM
chid's Avatar
I didn't want to tap into the original harness when I installed my Back-Off module, so I bought the connectors and I made a loop.
not very clear photo, but you can see the 2 original connectors (black) and my 2 new connectors white.
Black/yellow is ground, red is running light and blue (middle position) is brake light.
Versys 2015 Green
chid is offline
post #9 of 15 (permalink) Old 04-26-2016, 01:38 PM Thread Starter
Sorry for the double post. I thought the photos would be appropriate for this thread as well.
Original Post
http://www.kawasakiversys.com/forums...ml#post1128058
Givi E135 LED Brake Light Kit for V47 Top Cases
Custom Dynamics MagicFlex2 9" stip (cut off 3 LEDs to fit)
Custom Dynamics Plate Frames with LED TruFLEX® Light Bar & LED Plate Illumination
Photo 1: harness tapping into taillight.
Photo 2: diodes/resistor sets in green heat shrink. One set runs the topcase and the other runs the license plate. I added an extra resistor (red heat shrink) to the license plate to balance running lights.
Photo 3: The nest. I used so many connectors for testing and troubleshooting.
Photo 4: I was going to shorten the wires and solder connections, but it all stuffs nicely into the boot.
onewizard and chid like this.
IAMRA is offline
post #10 of 15 (permalink) Old 04-26-2016, 01:52 PM
Nice IAMRA.
I want to install E135 onto my Givi V47 on my 2015 Versys 650 LT. Any special trick you know of or instructions comes with kit?
maxversys is offline
post #11 of 15 (permalink) Old 04-26-2016, 02:16 PM Thread Starter
Originally Posted by maxversys View Post
Nice IAMRA.
Instructions come with. Wiring very easy. Need to drill two small holes for wires at marked locations under the lens. The only tricky part is knocking out the plugs where the quick connections install. Some people drill them out, but they will come out cleanly with an hard hammer blow. The tricky part is not denting the aluminum plate on the top of the case, while you hit the bottom with a hammer. I removed the aluminum top plate, just to be safe, and placed case upside down on some firm foam. I placed a metal racket handle with deep socket on top of the plug, and gave it a serious hammer blow. Knocking out the plug on the carrier plate of the rack is easier. Do this one first so you know how much force is needed. Also, one side of the quick connects are spring loaded, so take note that you wires move smoothly through the housing.
IAMRA is offline
post #12 of 15 (permalink) Old 04-26-2016, 07:00 PM
chid's Avatar
Very nice!!
you could use the horizontal LEDs as a turn signal too....
Original Post
Versys 2015 Green
chid is offline
post #13 of 15 (permalink) Old 04-26-2016, 07:47 PM
Great thread! Lot's of useful info.
post #14 of 15 (permalink) Old 12-07-2016, 09:21 PM
Resurrecting an old thread here - do you know the name/model of the connectors? I would like to buy some to do the same thing to my 2015 650 Versys. I see Eastern Beaver sells a ton of connectors, but I'm not sure which one I need.
Connectors
Thanks.
zirconx is offline
post #15 of 15 (permalink) Old 12-07-2016, 10:37 PM
Check Posts 1&2
Search "signal connectors" user; IAMRA find post by. I have copied to this thread and led sticky thread also.
