LAMS unrestriction - where is that plug? - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 04-09-2016, 06:18 AM Thread Starter
Tomasama's Avatar
Hello all,
while tinkering in the man-cave I started poking around to find where the plug is for the fuel/injector limiter on the LAMS restricted Versys.
I made a video to show you what I'm talking about...
If anyone could confirm you would be awesome!
Tomasama is offline
post #2 of 5 (permalink) Old 04-09-2016, 02:09 PM
post #3 of 5 (permalink) Old 04-09-2016, 02:28 PM
The connector you point out in the end of your video is the subharness connector for the ABS.
2015 Service Manual
https://dysk.onet.pl/link/U5pAw#.
IAMRA is offline
post #4 of 5 (permalink) Old 04-09-2016, 10:33 PM
According to my Kaw dealer, the 2015 V, like all the newer 650's, doesn't have the plug. Just remove the throttle stop with a security torx driver.
Two things to think about: firstly, if you are still on a restricted license removing the throttle stop may make you liable to prosecution. Same goes for removing the stop and not notifying the authorities. Once removed (legally) it can't be re-installed.
Do you really need the extra hp?. I had an unrestricted ER6n and never needed to rev it beyond 6k revs. Removing the stop probably won't give me anything.
BruceC
bc6805 is offline
post #5 of 5 (permalink) Old 04-16-2016, 07:13 AM Thread Starter
Tomasama's Avatar
Thank for the responses, it seems we're not quite there yet. I checked the link to the previous thread but that seems to reference an older model LAMS versys mk 1 mk 2?
The wiring seems different from the mk3.
Thanks Iamra for clarifying on the connector.
Looks like I'll go pay a visit to the Kawasaki dealer, though service department can be a bit hit and miss with unfamiliar models.
As for the extra power, we're taking about a 217kg bike with restricted ps/HP of 53 , this is no supersports. Unrestricted is 69 hp which is a 22% increase, mostly at the mid to top end.
Looking through the service manual it shows the following;
Maximum Horsepower
## 51.0 kW (69 PS) @8 500 r/min (rpm) compared with - (AU-LAMS) 39 kW (53 PS) @7 800 r/min (rpm)
and
Maximum Torque
##64 Nm (6.5 kgfm, 47 ftlb) @7 000 r/min (rpm) compared with (AU-LAMS) 57 Nm (5.8 kgfm, 42 ftlb) @3 800 r/min (rpm)
I'm wondering If remapping in the ecu is required...
Tomasama is offline
