Torquing the Rear castlenut. - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 03-21-2016, 07:47 PM Thread Starter
D3v
Hi.
dumb question, When torquing down the rear castlenut on my 08 versy, I know it has a torque value of 80ft lbs. But does the castlenut on the right side need to be torqued down as well?
thanks for the help.
D3v is offline
post #2 of 11 (permalink) Old 03-21-2016, 08:31 PM
Originally Posted by D3v View Post
Hi.
You should only have ONE castle nut on your rear axle. The other (right) side is the head of the axle bolt.
BTW there are NO dumb questions........
AlaskaJeff is online now
post #3 of 11 (permalink) Old 03-22-2016, 11:38 AM
Markie Motard's Avatar
Maybe he has a piece of all thread with two nuts on it. Just kidding
Markie Motard is offline
post #4 of 11 (permalink) Old 03-22-2016, 12:08 PM
GiantAntCowboy's Avatar
There should be the Axle Bolt Head on the right side (brake side) and a Castle Nut on the left (shifter side).
Basically you put a wrench on the Bolt Head to keep it from turning and then torque the Castle Nut to spec.
2008 Versys 650
Been riding 8 or 9 years, and have owned 8 or 9 bikes; its an addiction I can't quit...
GiantAntCowboy is offline
post #5 of 11 (permalink) Old 03-22-2016, 12:37 PM
Fly-Sig's Avatar
I put a wrench on the other side and let it jam up against the rear stand to keep the axle from spinning while tightening the castle nut. You only have to torque the one side to spec, the other side just needs to be held still so it won't spin.
Fly-Sig is offline
post #6 of 11 (permalink) Old 03-22-2016, 07:21 PM
When you torque your rear axle, you ARE torquing the whole thing, NOT just one side.
Then slightly decrease torque as necessary to line-up the cotter-pin hole.
post #7 of 11 (permalink) Old 03-23-2016, 10:00 PM
Fly-Sig's Avatar
My manual says to tighten until the next hole lines up, not loosen.
Fly-Sig is offline
post #8 of 11 (permalink) Old 03-24-2016, 01:04 AM
Mine too Eddie must have some inside info or something.
post #9 of 11 (permalink) Old 03-24-2016, 05:52 PM
I guess it all depends on how CLOSE the cotter-pin hole is to where the 80'/# takes you..., and in WHICH direction.
post #10 of 11 (permalink) Old 03-24-2016, 10:12 PM
Exclamation
No it does not, SUPER SPECULATOR! As directed in YOUR owner's manual:
-When inserting the cotter pin, if the slots in the nut do not align with the cotter pin hole in the ale shaft, TIGHTEN the nut CLOCKWISE UP to the NEXT alignment.
-It should be within 30 degrees.
-Loosen once and TIGHTEN AGAIN when the slot goes PAST the nearest hole.
post #11 of 11 (permalink) Old 03-25-2016, 11:40 AM
JACoH's Avatar
So, D3v, we are still in suspense, wondering what the issue you had with tightening the axle last month. Was it missing a spacer? I assume all is well, now that you are torquing the nut.
JACoH is offline
