Givi Airflow for Versys 650 2015 - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By chid
post #1 of 14 (permalink) Old 03-20-2016, 09:26 PM Thread Starter
chid's Avatar
I couldn't find any info, and on the Givi page for 2015 it shows a Gen 2 Versys, but with a windshield system from Gen 3 !?
GIVI AF4105 Airflow Windshield for Kawasaki Versys 650 - Kawasaki Versys 650 (2015) - GIVI Luggage
does it work on 650 2015?
Versys 2015 Green
chid is offline
post #2 of 14 (permalink) Old 03-21-2016, 01:43 AM
2linby's Avatar
Product : GIVI AF4105 Airflow Windshield
Fits Motorcycle : Kawasaki Versys 650 (2015)
Dimensions : 52 x 48 cm (H x W) 12 cm extension in height
Fitting Instructions : To view PDF CLICK HERE
The GIVI AF4105 sliding airflow transparent windscreen is specifically designed for the Kawasaki Versys 650. This airflow screen has 12 cm of extension. The AF4105 screen is to be mounted in place of the original Suzuki screen with a specific fitting kit that comes with the screen. Fitting instructions are included.
Ah? I'd be suspect of this until you've made a few phone calls....
COG# 5539
IBA# 15034
Team Oregon MC Instructor
"2linby" Get it? "Tooling by"
"Everything is simple, nothing is easy".
2linby is offline
post #3 of 14 (permalink) Old 03-21-2016, 08:13 AM
kawdog's Avatar
Wow! Good find. I was just getting ready to try my universal Airflow scoop on my Givi 410 tall shield. But after seeing the correctly sized one on that pic and remembering my universal one, it may not work. Givi is no help, although their short shield for the Mach 2 Vs. 650 may work better.
It's about freakin' time! Generation 3 Vs. 650 owners are getting some excellent options now. The Airflow is the most innovative and enjoyable windshield there is, bar none!
I wish it did work on Generation 2, but their help is minimum wage labor that just reads from catalogs. But that sure did 'look' good on that Generation 2, didn't it??
Well I've got notes to your vendor, Givi, and Twisted Throttle. All three will probably read me back what is in the catalog, lol.
kawdog is offline
post #4 of 14 (permalink) Old 03-21-2016, 10:21 AM
Cheftyler's Avatar
What's a Mach 2 Vs. 650?
Cheftyler is offline
post #5 of 14 (permalink) Old 03-21-2016, 01:40 PM
kawdog's Avatar
From Givi's US supplier Twisted Trottle, it's for the V1K and a misprint. Good for Saddlebag, if he wants to replace his 3rd party screen. I guess I'll dry to put the AF scoop on my Tall Givi screen, like I was originally going to do before: it should still work even if it is not optimum. What in the world is Honda/Bmw/Suzuki Givi thinking? Are there more V1K's than Vs. 650's out there?
I thought there were some funky lines on the gas tank I did not recognize: it was a Euro V1K before 2015
Twisted Throttle:
After doing some research it looks like the AF4105 was inaccurately listed by GIVI Italy as fitting the third generation Versys 650. The D4105ST and the AF4105 are actually for the '12-'14 Versys 1000 and the the photos of the screens on a Versys 1000 indicate this as well. There are slight accent differences between the bodywork that you can see if you compare the two machines, but at first glance it's not obvious. Givi informed me that there is not an "Airflow" style screen intended for the second gen Versys 650. You may want to consider one of the offerings from MRA for your machine as an alternative.
Regards,
Matt
kawdog is offline
post #6 of 14 (permalink) Old 03-23-2016, 04:50 PM Thread Starter
chid's Avatar
I found something interesting, is there anybody that can check this: (from the website of Kawasaki Canada)
Screen (taken from the Versys 1000) is approximately 1.7 times larger than that of the previous model.
it's the same screen? it means that the photo is right and it can work on 650 3rd gen.
Versys 2015 Green
chid is offline
post #7 of 14 (permalink) Old 03-24-2016, 03:49 PM
BKP
BKP's Avatar
I had a Madstad on my last bike... loved it... it was perfect... I know they're available for the 2015> Versys 650... Anyone have one?
Ride safe...
Barry
2015 Versys 650 Pearl White
[space holder for farkles...]
BKP is offline
post #8 of 14 (permalink) Old 03-24-2016, 05:37 PM
chid - I believe they are the same. I bought a Puig screen from an inmate, for my '15, and it's the SAME part # for 650 and 1000. Check the Puig site....
post #9 of 14 (permalink) Old 04-13-2016, 05:55 PM Thread Starter
chid's Avatar
Just to confirm, Givi Airflow AF4105 works on Versys 650 2015.
It works great actually
Wulff81 likes this.
Versys 2015 Green
chid is offline
post #10 of 14 (permalink) Old 05-21-2016, 07:14 AM
Just got my airflow yesterday for my 2016, just curious chid, what mounting adjustments have you settled on?
I'm starting out with the base set at the lowest position and the "chip" or top screen about 1in from the lowest. First ride planned for today.
TN-Versys is offline
post #11 of 14 (permalink) Old 05-21-2016, 10:07 AM
Wulff81's Avatar
The airflow on my 2015 is top notch.
Wulff81 is offline
post #12 of 14 (permalink) Old 05-22-2016, 03:56 PM
Installed a Madstad on my 2015 650LT in the middle height. Lots of adjustments and 2000 miles and not too impressed with it. Still a lot of turbulence/wind noise at the top of my helmet. I ordered one size higher than recommended but even all the way up, I still get more than I would like. Better than stock, but for me - not worth the cost.
YMMV.
dbardell is offline
post #13 of 14 (permalink) Old 05-22-2016, 04:38 PM Thread Starter
chid's Avatar
I did a nice 400km ride yesterday, very nice, I'm very impressed with Givi Airflow.
I was a lot less tired than before.
I could hear the engine on all speeds, easily up to 115km/h, that didn't happen before with the air noise and turbulences...
Versys 2015 Green
chid is offline
post #14 of 14 (permalink) Old 10-07-2016, 02:24 PM
Very happy with this screen.
The screen touch the handguards (screen maybe 1 cms too large) BUT it is not a problem for riding and for lock the handlebar.
The picture show the bike in locked position.
speedydom is offline
