2015 650 brake pad part numbers? - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 03-16-2016, 08:25 PM Thread Starter
I purchased this set of pads for the rear: http://www.amazon.com/EBC-Brakes-FA1...D3WAXGDGXFGGP7
EBC FA192HH as I read these were for the rear of the 650, 08-whenever. These don't fit my 2015. My rear caliper has an 8mm bolt that goes through the ring of both rear pads, looks like the front pads almost.
Where are the part numbers for this specific bike? I've spent so many hours trying to figure out what goes where when there's no info, I hate posting a question every time I need some little thing.
What other bikes use the same exact parts? It's been exceptionally hard to find parts or proper information for the Versys and Ninja 650s. I guess I'm looking and googling the wrong thing.
Modake is offline
post #2 of 10 (permalink) Old 03-16-2016, 09:32 PM
Kawasaki part # 43082-0151 for rear brake pads is exclusive to 2015+ Versys 650... They are however the same as used on 2006-2014 Yamaha YZF-R1.
EBC FA-174 organic: http://www.amazon.com/EBC-Organic-Br...ords=EBC+FA174
EBC FA-174V semi-sintered: http://www.amazon.com/EBC-Semi-Sinte...ords=EBC+FA174
EBC FA-174HH sintered: http://www.amazon.com/EBC-Brakes-FA1...ords=EBC+FA174
Vesrah VD-147JL sintered metal rear brake pads, as listed and shown for 2015 Versys 650: Catalog
https://www.kurveygirl.com/shop/prod...tm5rs2mhl849h4
http://www.amazon.com/Vesrah-Sintere...eywords=VD-147
They're also available from Brembo, Galfer, SBS, etc.
post #3 of 10 (permalink) Old 03-19-2016, 09:25 AM Thread Starter
Thanks for the parts! Where did you find that info?
Modake is offline
post #4 of 10 (permalink) Old 03-19-2016, 05:44 PM
post #5 of 10 (permalink) Old 05-06-2016, 04:02 PM Thread Starter
These don't fit my 2015. The ends have a taller rear notch (2 posts with an empty space in the middle). This prevents the front from raising up high enough for the bolt to clear. I'm going to try and grind it down an 1/8" but there isn't much to work with.
Modake is offline
post #6 of 10 (permalink) Old 05-06-2016, 07:02 PM
That's strange... Vesrah pad listed for 2015 Versys 650 is in fact the same as yours as shown in diagram, and it's also listed for Yamaha R1.
Vesrah VD-147JL sintered metal rear brake pads for 2015 Versys 650: Catalog
post #7 of 10 (permalink) Old 05-06-2016, 07:07 PM
post #8 of 10 (permalink) Old 05-08-2016, 08:33 PM Thread Starter
The EBC pads I have have a taller end part which is split into two instead of being a solid one. I had to grind one of the tabs down halfway to get it to fit, it was simply too tall.
My pads look a little different from the EBC photo (They are marked FA174HH and has correct packaging), but you can see the difference between those and the pic you posted, the EBC has a taller tab.
At least it fits now.
Modake is offline
post #9 of 10 (permalink) Old 05-08-2016, 09:12 PM
You mean yours are like my 1st photo in this thread of the EBC FA174HH pads... Vesrah VD-147JL pads listed for your 2015 Versys 650 do have the proper dimensions, as seen in the Vesrah pads photo you just quoted me about.
post #10 of 10 (permalink) Old 05-09-2016, 07:11 PM Thread Starter
Yeah, it looks like the Vesrah would work perfectly fine, but you can see in the EBC photo that that tab is much taller (located more towards the bottom of the pad).
The EBC pads also have a U shaped tab rather than a solid tab like the Vesrah.
I haven't bedded them in, will do tomorrow, but the first ride was fine and my ABS didn't kick on like it usually does. I hear a lot of rotor grind as usual with new pads.
Modake is offline
