Frame Sliders, or Cowling Guards - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 07-31-2010, 03:08 PM Thread Starter
Kel
Has anyone used frame sliders other than the more expensive Kawasaki brand? If so, how do you like them, how much where they and where did you get them? Thanks....
Kel is offline
post #2 of 10 (permalink) Old 07-31-2010, 09:53 PM
Most people are using either the Hepco and Becker or the Sw-Motech engine guards. Sliders can tend to do more damage since they are mounted with all the stress at one point were as the guards have more surface area.
A search can locate them easy.
2009 Lime green Versys
Hepco & Becker crash bars
Givi side carriers w/ E21's
Fenda Extenda
cut tail fender
black lower panels
Sw-Motech 20mm riser
Randy49 is offline
post #3 of 10 (permalink) Old 07-31-2010, 10:21 PM
brothercannon's Avatar
Or use both.
I've never laid down my V so I do not know how effective the fairing sliders would be. I think the engine guard would take the brunt of the damage and the slider would keep the fairing off of the ground but with out much weight on it. I would not use these sliders on their own without the engine guard. I got the sliders from a seller on ebay and they are meant for a ninja 650r but bolt in just fine.
brothercannon is offline
post #4 of 10 (permalink) Old 08-01-2010, 08:58 AM
Use both, but the frame slider wont be able to save you from damage as its mounting is such. Better to use H&B crash bars. My V came with the frame slide so just left it there.
post #5 of 10 (permalink) Old 08-02-2010, 03:59 AM
motojoe's Avatar
Brothercannon, I looked all over. Where exactally can I find that small slider to protect the fairing. Thanks.
motojoe is offline
post #6 of 10 (permalink) Old 08-02-2010, 08:17 AM
I found these sliders from they same seller I purchased mine from. The look like the same thing but are aluminum and not plastic.
http://cgi.ebay.com/ebaymotors/2005-...Q5fAccessories
post #7 of 10 (permalink) Old 08-02-2010, 08:32 AM
Try this cool ones and are more practical in design for use on cowling.
http://www.indysuperbike.com/custome...t=33657&page=1
post #8 of 10 (permalink) Old 08-02-2010, 09:15 AM
Fastoman, your link took me to Yamaha R6 frame sliders. Do they fit the V?
Tex Vs is offline
post #9 of 10 (permalink) Old 08-02-2010, 09:26 AM
They have ones for the V and I am sure someone here in the forum has posted it.
This slides are better to be fitted to the cowing as they are more flushed to the cowling then the others.
post #10 of 10 (permalink) Old 08-02-2010, 09:32 AM
http://www.kawasakiversys.com/forums...+frame+sliders
http://www.spieglerusa.com/cfm/FrameSliders.cfm (try this link and they have one for the V)
found the thread. Here is all on Frame sliders.Hope it helps.
