WATERPROOF Power Outlet Options? - Kawasaki Versys Forum
Like Tree2Likes
  • 1 Post By kohburn
  • 1 Post By kawdog
post #1 of 13 (permalink) Old 02-12-2016, 11:39 AM Thread Starter
Speedy83's Avatar
I did a forum search and located a number of threads on power outlets, but none of them appeared to be waterproof when in use or otherwise.
I have ordered the "relay kit" for my 2015 650 and I was originally going to use it in conjunction with my Garmin power cord (which, with an adapter, can also be used to charge my iPhone).
I am most concerned about riding in the rain without my GPS plugged in (connector exposed to the elements).
Any good solutions/suggestions?
I have considered adding a waterproof switch.
Anybody using a GIVI, 3BR or Euro style WATERPROOF setup?
Thanks.
Speedy83 is offline
post #2 of 13 (permalink) Old 02-12-2016, 12:29 PM
Thanks.
What I did is install a outlet powered off the city lights, below the fairing on the left by the TPS, I then plug in my cigarette lighter to usb cord, this attaches to behind my GPS which is mounted behind the windshield , never had a problem. Kawaskai makes a relay kit that mounts in this location, my plan is to duplicate what I had before, as I have the kit on order for my 2015, but will be using it primarily for the heated grips. The provisions in the dash will get a USB / 12 VDC lighter outlet that can be used for dry weather . Will also add a waterproof one on right side rated for 30 amp , very close to were the rear remote adjust for the shock is.
onewizard is online now
post #3 of 13 (permalink) Old 02-12-2016, 12:44 PM
kohburn's Avatar
I've never seen one that claimed to be waterproof during use. mine are the marine style so they have the rubber covers.
silviefox likes this.
kohburn is offline
post #4 of 13 (permalink) Old 02-12-2016, 01:24 PM
its 12-14V dc with well separated contacts, water really isnt going to hurt it (at most corrode the contacts a bit quicker just WD40 them )
post #5 of 13 (permalink) Old 02-12-2016, 01:37 PM
Narva USB Dual Flush Mount Socket 81134BL New Car Caravan Adapter 4x4 | eBay
post #6 of 13 (permalink) Old 02-12-2016, 02:13 PM
Didn't someone recently show a combo 12V lighter and USB port power outlet. BTW, does that Navara unit actually have a back light?
rayj
2009 Versys (Mine's Green)
rayj is offline
post #7 of 13 (permalink) Old 02-12-2016, 02:18 PM
Cheftyler's Avatar
Mine does (still sitting on my kitchen counter). And it has a boot that make the USB port water resistant.
Cheftyler is offline
post #8 of 13 (permalink) Old 02-12-2016, 05:24 PM
chid's Avatar
There are some power outlet that have a "locking/clicking" mechanism with the connector that are waterproof in use.
Marine-Grade-Locking-Cigarette-Lighter
Versys 2015 Green
chid is offline
post #9 of 13 (permalink) Old 02-12-2016, 07:45 PM
Yes
post #10 of 13 (permalink) Old 02-12-2016, 10:16 PM
kawdog's Avatar
I've got:
1) a cigarette lighter on my handlebars with a rubber cap on it (for my air pump if I ever need it,)
2) Battery Tender leads on my battery to charge it with a rubber cap on it, and
3) a Battery Tender extension cord from my battery charging line (2) to a dual USB Battery tender(/cigarette lighter) connector inside my almost water/air proof Seahorse 720 tail bag (probably the most waterproof example under any weather circumstances outlet option - Note: not good for under 200 ft of water :-)
I just use the battery charger (2) every day. The others are in case of emergency, convenience, and general living in luxury
kawdog is offline
post #11 of 13 (permalink) Old 02-13-2016, 08:04 AM
Originally Posted by kawdog View Post
I've got:
You meant, not good below 200 ft
How do you know??
post #12 of 13 (permalink) Old 02-14-2016, 09:47 AM Thread Starter
Speedy83's Avatar
Thanks for the input guys.
I ended up purchasing the 3BR Tapp Lite USB Charger with two TAPP Caps from twistedthrottle.ca.
TAPP LITE USB Charger (Discontinued) - TwistedThrottle.ca
Tapp Capp universal USB cable weatherproofing kit - TwistedThrottle.ca
With shipping, it came to $78.56CAD. A little pricey, but should be a sweet setup in conjunction with my relay, SW Motech GPS mount and Zumo. At 5v/1A, it will also work to charge my iPhone.
And the best part is that it's waterproof.
Speedy83 is offline
post #13 of 13 (permalink) Old 02-14-2016, 10:53 AM
MaverickAus, I don't think the Narva is sold in the states, and it looks like the manufacturer/distributor won't go for the shipping costs. That is a nice unit that is really cheap. I mean inexpensive.
rayj
rayj is offline
