Do I have to modify the kickstand if I lower? - Kawasaki Versys Forum
 6Likes
post #1 of 26 (permalink) Old 02-01-2016, 09:20 AM Thread Starter
I'm about to lower in preparation for spring, going for about a 2-2.25" drop. How necessary will it be to change the kickstand? I'm not using speedy's blocks but I guess I can get the flatfoot if people are convinced it's the best option.
I've seen the advice to do a KLR stand swap, and I think this is what I'd really like to do, if I do that, will it also need chopped? Will any that I find fit my 2013?
I have a welder and a grinder and such but I'm exactly awesome with the welder.
Seems crazy to me that replacement kickstands are more expensive than the lowering blocks.
AdventureSeeker is offline
post #2 of 26 (permalink) Old 02-01-2016, 09:36 AM
kohburn's Avatar
yes you will need a shorter stand
you can either cut the stock one down and weld a foot back on or clamp on a larger foot
or you can use the stock stand from a 650 ninja (probably 20$)
AdventureSeeker likes this.
kohburn is offline
post #3 of 26 (permalink) Old 02-01-2016, 10:06 AM Thread Starter
Thanks for the speedy reply. I park on a lot of grass/gravel, that's why the larger foot is ideal. Hmmm.
post #4 of 26 (permalink) Old 02-01-2016, 10:17 AM
kohburn's Avatar
yeah I park in grass and the soil around here is mostly sand so I installed a KLR650 kickstand
would be easy to shorten one of those also its mostly round tube.
see my kickstand thread..
http://www.kawasakiversys.com/forums...kickstand.html
the picks show a piece of rock at the stand but that was from before installing the klr stand, since then I just put it down right on the sand and it has been getting parked like that daily since.
kohburn is offline
post #5 of 26 (permalink) Old 02-01-2016, 03:33 PM Thread Starter
Thanks. Your post was actually the first one I saw wrt the KLR swap. Do you know if it matters what year KLR stand I find?
post #6 of 26 (permalink) Old 02-01-2016, 04:34 PM
kawdog's Avatar
I just went through the same decision process when I lowered my 2012 with Speedy's kit, but I left the front forks up - lowered it about 1.6". Another kit from Europe looked about the same: 1.6" front forks up (std) and 2" front end adjusted down. I'd estimate the T-Rex would be similar, since I think most vendors usually just copy the innovator's product design, Speedy's.
Based on expert owners here (HondaGalToo, who also races), I got the 2012 Ninja 650 kickstand which is 1" shorter. It works perfect for me, and evidently for her as well on the fully lowered, about the same as yours. It tucks in perfect when up. But if you are parking in mud puddles, it is the same end as stock and won't help you there. Most people don't park in mud puddles though, but if you do, there are several choices (some more expensive like you mentioned.)
I got mine from ebay for $20 including shipping with new springs and nut/bolt hardware in 2 days(!) I sprayed a couple of coats of Rustoleum over night with my space heater under it, and it looks like brand new now and fits like stock in the up and down position.
onewizard and AdventureSeeker like this.
kawdog is offline
post #7 of 26 (permalink) Old 02-01-2016, 04:53 PM
I notice you just shot those pictures today. I am sure I could weld something up, but I would prefer something ready made, just with the exchange of the dollar and shipping, it comes close to what I paid for my lift. The question I have is that Pit stand, what you paid for it and where you bought it, last time I checked it was over $200 USD, plus shipping.
post #8 of 26 (permalink) Old 02-01-2016, 05:17 PM Thread Starter
Excellent writeup and photos kawdog, very much appreciated. Thanks.
post #9 of 26 (permalink) Old 02-01-2016, 08:07 PM
chadams66's Avatar
I got the Motowerk Flatfoot when I lowered my bike...no problems after 3 years of use...
Flatfoot for Lowering Kit for Kawasaki Versys
chadams66 is offline
post #10 of 26 (permalink) Old 02-01-2016, 09:23 PM
kohburn's Avatar
I don't think it makes a difference but I used one from the same year range as my versys
kohburn is offline
post #11 of 26 (permalink) Old 02-01-2016, 10:02 PM
2008 and up have the offset, 2007 and down are straight. it's not worth cutting the KLR sidestand for a lowered bike, just use the ER6F(Ninja, EX650) sidestand.
raising the Versys is a different story, then the 2008+ KLR is the one and only.
jdrocks is offline
post #12 of 26 (permalink) Old 02-01-2016, 10:07 PM
kohburn's Avatar
good info - i really like the offset one.
kohburn is offline
post #13 of 26 (permalink) Old 02-02-2016, 12:17 AM
E327's Avatar
I also use the flatfoot - it put my bike at a much better angle when parked and also much more secure in soft surfaces. Love it. Mine is also only lowered in rear.
E327 is offline
post #14 of 26 (permalink) Old 02-02-2016, 08:45 AM Thread Starter
Thanks for all the info everyone. I was noticing the difference in angles. I think I'm gonna give it a shot cutting down the one I've got and then seeing what happens from there.
post #15 of 26 (permalink) Old 02-02-2016, 09:37 AM
kohburn's Avatar
if you find yourself in need of a stock one, I've got one sitting on my bench
kohburn is offline
post #16 of 26 (permalink) Old 02-02-2016, 12:10 PM
One more thing to keep in mind if you purchase Speedy's bolt on flatfoot (which I love, btw). The newer Versys have a wider kickstand tube (not sure if all 2nd gen, but my 2013 has the wider one). So if you get the flat foot, be sure to order it for the year and bike model kickstand you get.
HondaGalToo is offline
post #17 of 26 (permalink) Old 02-02-2016, 01:47 PM
As jdrocks said - '08 and newer KLRs.
post #18 of 26 (permalink) Old 02-23-2016, 09:11 AM
SpyvsSpy's Avatar
So being that I have a 2011 Versys, what lowered kickstands work for me?
I found a few er6n and ninja 650's of different years on ebay
SpyvsSpy is offline
post #19 of 26 (permalink) Old 02-23-2016, 09:59 AM
kohburn's Avatar
I believe that they should all work
kohburn is offline
post #20 of 26 (permalink) Old 02-24-2016, 12:54 PM
wb57's Avatar
I did exactly this and it works great. $11.00 on eBay.
kohburn likes this.
'11 Versys
'07 KTM 250 XC-F
wb57 is offline
