Stripped Clutch Switch Screws - Kawasaki Versys Forum
 5Likes
  • 4 Post By invader
  • 1 Post By silviefox
post #1 of 13 (permalink) Old 01-28-2016, 09:23 PM Thread Starter
I stripped one of the screws (and lost the other) trying to remove my clutch switch (part# 27010-1094)
Can someone please tell me what the screw size is so I can buy new ones?
redtaped is offline
post #2 of 13 (permalink) Old 01-28-2016, 09:56 PM
Screw # 92172-0183 is M3 (3mm) x 16mm thread length.
2012 Kawasaki VERSYS (KLE650CCF) Handlebar | Part Shark
post #3 of 13 (permalink) Old 01-28-2016, 11:04 PM
I highly doubt you stripped the thread off a steel screw in an aluminium housing, more likely the thread in the housing is stripped. I hope I'm wrong.
post #4 of 13 (permalink) Old 01-28-2016, 11:24 PM
im hoping he meant he stripped the head by using a US Philips screw driver on it
post #5 of 13 (permalink) Old 01-29-2016, 04:53 AM
Good point
post #6 of 13 (permalink) Old 01-29-2016, 05:41 AM
Good point
That's what I did when I was replacing the clutch lever. I had a heck of a time trying to get that nut off and thought removing the switch would help things out. Heck no. Whoever assembled that part must have used the highest grade Loctite. If it's a steel screw, they must have used the most pliable steel they could find. It didn't take any effort on my part to strip out the head.
blazblu82 is offline
post #8 of 13 (permalink) Old 01-29-2016, 09:59 AM
useing the wrong tool will do that (thats why most my stuff is that way, im the WRONG tool )
you could take a cut off wheel and turn the stripped screw in to a standard screw then just use a flathead in it (just not mine)
post #9 of 13 (permalink) Old 01-29-2016, 05:06 PM
chadams66's Avatar
invader has it right...get Japanese phillips head screw drivers...it's totally amazing how well they work..on Japanese bikes and cars...
chadams66 is offline
post #10 of 13 (permalink) Old 01-29-2016, 06:09 PM
i use the one kawasaki provided me under the seat
post #11 of 13 (permalink) Old 01-29-2016, 09:34 PM
I have these, best screwdivers I have ever used
post #12 of 13 (permalink) Old 01-29-2016, 10:24 PM
There's JIS (Japanese), and there's also Phillips (USA) like yours, and yet different again is POZI (British)...
https://www.kincrome.com.au/screwdri...SizeProduct=50
post #13 of 13 (permalink) Old 01-30-2016, 02:25 AM
If I used that "junk" I'd have to use the dremel again to get it to work right like the tool used to adjust the rear shock. *eye roll with butter*
