How much oil to add? - Kawasaki Versys Forum
 2Likes
  • 1 Post By GiantAntCowboy
  • 1 Post By waltermitty
post #1 of 15 (permalink) Old 01-12-2016, 12:47 PM Thread Starter
Hi All, The viewing glass on my 650 is showing about 1/3 of the range on oil. I would like to top it up a little today for a high speed run tomorrow. How much should I add to bring it up to near full? I will try to do it in stages, but there is nobody here to hold the bike while I add. Thanks
cjcintucson is offline
post #2 of 15 (permalink) Old 01-12-2016, 01:44 PM
the two lines is about 1/2 quart
post #3 of 15 (permalink) Old 01-12-2016, 02:06 PM
GiantAntCowboy's Avatar
Honestly your oil level is probably fine now.. but you could add 1/3 of a quart to raise it a bit, if i'll help you sleep at night.
haha
silviefox likes this.
2008 Versys 650
Been riding 8 or 9 years, and have owned 8 or 9 bikes; its an addiction I can't quit...
GiantAntCowboy is offline
post #4 of 15 (permalink) Old 01-12-2016, 02:46 PM
you can use a brick or some wood to put under the kickstand to level the bike....
post #5 of 15 (permalink) Old 01-12-2016, 03:09 PM
The best method (imho) to get the bike level is to balance it on its wheels. I squat down and pull the bike over to the tipping point while observing the oil window. I add oil about 2 oz at a time to get it to the top line.
waltermitty is offline
post #6 of 15 (permalink) Old 01-12-2016, 03:22 PM
BLACK DOG's Avatar
I remember another inmate setting a mirror on the floor so he could see the oil level while he straddled the bike.
BLACK DOG is offline
post #7 of 15 (permalink) Old 01-12-2016, 05:33 PM
I have a mirror on the ceiling of my bedroom.
post #8 of 15 (permalink) Old 01-12-2016, 06:29 PM
BLACK DOG's Avatar
there are some things I'd rather not see
post #9 of 15 (permalink) Old 01-12-2016, 06:34 PM
Yeah, I remember pulling the bike over onto myself one time doing that balance trick. Thank God the V and I got out without any injury, except for my pride in trying to tell my wife what the hell happened.
rayj
2009 Versys (Mine's Green)
rayj is offline
post #10 of 15 (permalink) Old 01-12-2016, 07:23 PM
you could also just put the bike on the rear stand d(if you have one)
post #11 of 15 (permalink) Old 01-12-2016, 07:46 PM
a quick and dirty is a brick under the side stand... as mentioned above
but you can also rest the bike against a tree or pole against the rear grab handles.
Tie the bike off with some rope so it wont fall on you... then you do a quick top up.
I always have a 10m x5mm thick rope under my seat. Always handy.
Gigitt is offline
post #12 of 15 (permalink) Old 01-12-2016, 11:53 PM
SpyvsSpy's Avatar
I use a 2x4 to straighten up the versys and secure it to some beams in the garage ceiling with some rope. Works nicely.
SpyvsSpy is offline
post #13 of 15 (permalink) Old 01-13-2016, 10:12 AM
Markie Motard's Avatar
Gigitt said pole
Markie Motard is offline
post #14 of 15 (permalink) Old 01-13-2016, 11:22 AM
Y'all are make this so hard. Can't believe I said that.
post #15 of 15 (permalink) Old 01-14-2016, 02:59 PM
I do pretty-much the same, EXCEPT I bend over to see the oil-level, and USUALLY do it while riding when I stop for something, say at the library.
I add oil if necessary, at home, and just a bit at a time, pulling the V to vertical to check after adding it. BASICALLY - except for when I had an oil-leak near the water-pump on my '08 - I NEVER add oil between changes (each 5,000 miles//8,000 kms), and the '08 has 60,800 miles on it, SO FAR...!
