1st B1tch - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 10-17-2015, 10:23 AM Thread Starter
millarg's Avatar
1st B1tch
My rear wheel is nasty, I have been following so advice to lube chain (I use spray chain lube) at each fuelling.
I have an 08 with Clear coated wheels, as you will know the outer edge of each side is smooth, but the inner 1/3 including spokes and hub has a textured finish which the dirt just loves to cling to.
I spray rear wheel down regularly, but the grim is hard work to remove.
B1tch over! How do y'all keep your rear wheel clean?
Glen 08 Red
millarg is offline
post #2 of 12 (permalink) Old 10-17-2015, 12:56 PM
Rarely.
If the bike is a little dirty, then I never shy away from taking that mini adventure down a dirt road I've never seen before. So I don't sweat the details too often.
Having said that, if it's clean up time: S100 spray on and hose off. Or, for more detailed cleaning, scrubbing with a bit of WD40 works well.
post #3 of 12 (permalink) Old 10-17-2015, 12:59 PM
Only need to lube you chain about every 500 miles...But i use this ..!BcKEoKQ!2k~$(KGrHqYH-CgEqu!U6SwdBKzQDZyeHQ~~_35 by weljo2001, on Flickr and a rag to clean my wheels
post #4 of 12 (permalink) Old 10-17-2015, 02:40 PM
Baron650's Avatar
Baron650 is offline
post #5 of 12 (permalink) Old 10-17-2015, 06:10 PM
I use WD40 on paper towel...
De-greases tar and grime easy, Cleans quickly, Lubricates if left on bike, and Shines in one hit!
I don't want to introduce any other decreasing agent that could wash away all my chain oil
Using Pro-Oiler electronic automatic Chain Oiling system
Gigitt is offline
post #6 of 12 (permalink) Old 10-18-2015, 09:44 AM
WD-40 and spray wash and wax keeps mine nice and clean
post #7 of 12 (permalink) Old 10-18-2015, 12:16 PM
blipco's Avatar
For the rear wheel I'm with the WD40 crowd. Spraying it on a soft cloth works better than a paper towel.
blipco is offline
post #8 of 12 (permalink) Old 10-18-2015, 01:12 PM
...How do y'all keep your rear wheel clean?
I do the same as blipco, but not TOO often...!
post #9 of 12 (permalink) Old 10-19-2015, 06:07 AM
ggg
ggg's Avatar
MR SHEEN furniture polish, cleans a polishes in one go.
good for the whole bike, as per can instructions
ggg is offline
post #10 of 12 (permalink) Old 10-19-2015, 10:50 AM
Banned
Awesome!
That's what use.............
No, not Mr fkin Sheen ya poofta, Awesome!
my2wheels is offline
post #11 of 12 (permalink) Old 10-20-2015, 10:06 AM
outdoorgb's Avatar
Used to use "Honda Shine" but dealer is not close to me...Now I use Cycle Gear Original Bike Spirits Polish. Or, just my typical car wash soap and a dedicated wash mit.
The Bike Spirits works great on helmet shields too...micro fiber cloth to prevent scratches.
outdoorgb is offline
post #12 of 12 (permalink) Old 10-20-2015, 11:00 AM
Soap. Water. Elbow Grease. Repeat.
There is no easy way. Unless you have someone else wash your bike for you.
visitor zero is offline
