Horn Install - Big Dog - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 06-08-2010, 06:34 PM Thread Starter
dallasdon's Avatar
I picked up this horn at Harbor Freight (http://www.harborfreight.com/bad-boy...-94117.htmland ) I'm sure it's a knock-off of Steible and Nautlis but it works just fine. I installed it inside the cowl on the left side of the bike above where the old horn was.
I cut two wires about 16" long for an extension from the stock horn location and attached female and male ends and quick connected to the stock horns wires. I then mounted the horn with electrical ties and padded the back side of the new horn against the tank. It took all of about 30 minutes and works great. Then new horn came with a relay but you don't have to use it as it is designed to just be plugged into your stock horns wiring.
It works fine and is very loud and it's out of the weather. There is no clearance issues with the fork or the fairing. Just passing info along.
'09 Versys -Green
TET'68 Survivor
dallasdon is offline
post #2 of 4 (permalink) Old 06-08-2010, 08:08 PM
spiderman's Avatar
Score another good one for DD!
Jeff in Illinois
07 Bandit
03 KLR
82 Rokon
spiderman is offline
post #3 of 4 (permalink) Old 06-09-2010, 03:26 AM
Thanks for sharing.
post #4 of 4 (permalink) Old 06-09-2010, 03:15 PM
I believe it's called the "WOLO Bad Boy".
