Drilling back rest - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 06-06-2010, 07:25 AM Thread Starter
Drilling back rest
Hi all
quick questions, can I use a drill bit for metal to drill the holes in the topbox or will I really screw things up? If it's not advisable I would rather know than try it since once the holes are there there is nowt I can do about it.
spainy is offline
post #2 of 4 (permalink) Old 06-06-2010, 07:57 AM
Originally Posted by spainy View Post
Hi all
Yes, you may use metal bits to drill plastic. If I may offer, depending on hole size...If large diameter, drill a small pilot hole through, then increase the size a couple times until you get to the required size. It will be a much cleaner hole and the bit wont pull through the plastic.
post #3 of 4 (permalink) Old 06-06-2010, 10:40 PM
Metal drill bits can be used for a variety of use. Start with a small dia first so that you are sure of your centre point for a big dia hole.
Take your time to be sure of the location where you want the hole drilled, then set a punch to mark the hole before drilling.
Goodluck on whatever you are drilling.
post #4 of 4 (permalink) Old 06-07-2010, 03:44 AM Thread Starter
Thanks for the advice guys!! I have a template for where to put the holes so it should go smoothly .
spainy is offline
