Does the Peg Lowering Kit Really Make a Difference? - Kawasaki Versys Forum
post #1 of 15 (permalink) Old 08-16-2015, 08:51 AM Thread Starter
Getting use to my new V1K. Man, this is one sweet ride.
Trying to get it broke in, but other things keep getting in the way of my riding.
I have noticed I feel cramped after about an hour or so. I will be getting around to getting some crash bars and highway pegs, but in the meantime I thought I'd lower the factory pegs.
Any pros or cons from people who have done the peg lowering would be appreciated.
otrp is offline
post #2 of 15 (permalink) Old 08-16-2015, 09:06 AM
I lowered them on my 08' and felt it made a huge difference on a medium to long ride. I could ride short distances no problem before but starywd to cramp up.
As for negatives, if you lean it over far enough it is easier to drag your pegs in the turns.
08' Versys
HAWKSHOT99 is offline
post #3 of 15 (permalink) Old 08-16-2015, 09:48 AM
At 6'04" with a 36" inseam, it made a big difference for me.
I used these
http://www.shop.motowerk.com/Versys-650_c2.htm
As well as the flat foot and mirror extenders.
I also added a tapered shim (thicker in the front to level out the seat) under an airhawk.
Total change with the two mods is probably 2" and it made a huge difference in longer ride comfort.
Mitch
Slow-Steady is offline
post #4 of 15 (permalink) Old 08-16-2015, 09:59 AM
Time's Avatar
My 2012 was a little small in the cockpit for longer trips and I felt like my knees were in my chest. With the peg lowering kit and bar riser the cockpit now is larger than my KLR or at least the same size. I can roll for hours without a problem.
I'm 5'11" with a 31" inseam and hit the scales at 160 so you have something to go one.
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #5 of 15 (permalink) Old 08-16-2015, 11:51 AM
yes
post #6 of 15 (permalink) Old 08-16-2015, 12:03 PM
scooter650's Avatar
yup
best investment I've made for the machine (knee issues due to old mva)
scooter650 is offline
post #7 of 15 (permalink) Old 08-16-2015, 12:31 PM Thread Starter
Sounds good. I will get a set. Thank you all for the input.
otrp is offline
post #8 of 15 (permalink) Old 08-16-2015, 01:18 PM
DaveC's Avatar
You won't be disappointed. Best upgrade ever for me (6', 32" inseam, 230 lbs).
Dave C
2008 Versys (Red)
DaveC is offline
post #9 of 15 (permalink) Old 08-16-2015, 05:59 PM
kawdog's Avatar
If you can touch one toe on the ground now, yes, it will make a big difference.
The perfect knee angle is 90 degrees, not 45 degrees or less (eventual cramp city blues.) ymmv
kawdog is offline
post #10 of 15 (permalink) Old 08-17-2015, 08:37 AM Thread Starter
I guess after lowering the pegs, I will have to adjust the shifter and brake levers?
otrp is offline
post #11 of 15 (permalink) Old 08-17-2015, 08:54 AM
Yes. Or, highly likely, rather.
Soldier311 is offline
post #12 of 15 (permalink) Old 08-17-2015, 09:16 AM
E327's Avatar
I lowered my pegs on my v650 and did not adjust the shifter or the brake pedal. Actually I found the angles much better. Don't know about v1000 but I would try it.
E327 is offline
post #13 of 15 (permalink) Old 08-17-2015, 09:29 AM
Wait a minute...
OP is asking about a V1K, replies are from V650 owners... The ergos are quite different.
Süsser Tod is offline
post #14 of 15 (permalink) Old 08-17-2015, 09:40 AM
Originally Posted by Süsser Tod View Post
Wait a minute...
I saw that, and hopefully he will get a reply or two from the 1K owners.
However, regardless of the bike, if he feels cramped, lowering the pegs will lessen leg angle and provide more "room".
Mitch
post #15 of 15 (permalink) Old 08-23-2015, 04:25 PM
...Any pros or cons from people who have done the peg lowering would be appreciated.
I've had them on my '08 and '09, but didn't think the '15 would need them, due to the lower 'pegs from Kawi. Put them on, tho', and REALLY like them, as I tend to stand on the 'pegs a lot, and they add lots of room!
