Simple Green - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 05-27-2010, 08:49 PM Thread Starter
Simple Green
Quick, easy question.
When people refer to Simple Green, which type do you mean:
1)Simple Green All-Purpose Cleaner
or
2) Pro Series Simple Green MAX (cleaner and degreaser)?
It might be a bit of a stupid question, but if nobody uses the all purpose cleaner, I don't want to put it all over my bike
The degreaser seems like the obvious answer, but everybody always says "Simple Green", so I thought I'd be safe and ask .
Thanks!
"I refuse to tiptoe through life only to arrive safely at death."
Banack is offline
post #2 of 7 (permalink) Old 05-27-2010, 08:55 PM
simple green in great, but don't use it on aluminum parts such as your engine
lifesAnOcean is offline
post #3 of 7 (permalink) Old 05-27-2010, 09:58 PM Thread Starter
Agreed, but I am still wondering what type of Simple Green to get.
I dare don't put any chemicals on my aluminum parts
Banack is offline
post #4 of 7 (permalink) Old 05-27-2010, 10:25 PM
All Purpose Cleaner use it on everything (put some in a bucket and fill with water, probably 1:30-40 dilution) and never had any problems with aluminum wheels or engine parts. Read the literature, it's not a corrosive cleaner.
Gustavo
Gustavo is offline
post #5 of 7 (permalink) Old 05-27-2010, 11:31 PM Thread Starter
Thanks for the reply Gustavo. When I replied to the previous post about not putting chemicals on, I meant spraying straight Simple Green on my aluminum. I hadn't used it before and didn't realize the dilution ratio was so high. Based on the responses from you and numerous other people in different threads, it sounds like it's a safe product to use
3rd heading down http://www.simplegreen.com/solutions..._backup=danger
Aluminum - Is it safe to use Simple Green® on aluminum?
When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. Simple Green All-Purpose Cleaner, Crystal Simple Green® Cleaner/Degreaser, Simple Green Pressure Washer Concentrates, and Pro Series™ Simple Green® Automotive Cleaner have been used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green® product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation. "
The only reason I asked is because there has been some discussion on it:
http://www.autopia.org/forum/car-det...-aluminum.html
http://www.v-twinforum.com/forums/mo...ple-green.html
Banack is offline
post #6 of 7 (permalink) Old 05-28-2010, 07:36 AM
I use Simple Green all the time in a Sprayer 50/50 with water. Works great and does not affect the Aluminum or Painted surfaces. I have been doing this for years, on all colors and brands of bikes without any bad results. Even on Dirt bikes where there is plenty of Raw aluminum.
Todd
tapntx is offline
post #7 of 7 (permalink) Old 05-28-2010, 09:21 AM Thread Starter
Beautiful. I'll take first hand experience/advice from you guys over a bunch of people speculating on other fourms. Thanks for the responses
Banack is offline
