Which seat?? - Kawasaki Versys Forum
post #1 of 22 (permalink) Old 06-27-2015, 10:49 PM Thread Starter
Which seat??
I have a 2015 650 and after riding it for more than an hour I feel like I am riding my balls like a Hippity Hop. It is super uncomfortable. What seat would you guys recommend? I am about 5'10" with a 30" inseam and I don't have much of a butt. I have lowered the bike already too if that makes any difference.
thekrnl is offline
post #2 of 22 (permalink) Old 06-27-2015, 11:18 PM
Avande's Avatar
I've always found the stock seat ok but recently I added a couple of washers to the seat hold down latch base bolts, which raised it slightly in the front and it made a nice difference. I think there's a couple of threads about guys buying longer bolts and adding several washers to raise the front. It's an inexpensive first step that may work and if not you can still move to an aftermarket seat.
Lovin every minute of it!
Avande is offline
post #3 of 22 (permalink) Old 06-28-2015, 09:11 AM Thread Starter
This is interesting. Wouldn't it actually make it worse for your junk smashing into the front seat though? I would think that it would cause the seat to raise into you more.
thekrnl is offline
post #4 of 22 (permalink) Old 06-28-2015, 09:37 AM
Fly-Sig's Avatar
I've found the same issue with my '15. When the seat is cold everything is fine. After a few minutes it softens up, and there is a forward tilt to it. I'm 5'10", 155 lbs.
Seat Concepts has a kit to replace the foam. http://seatconcepts.com/products#!/K...tegory=1671354 They'll install it for you for another $20 plus shipping. The kit gets good reviews from members here.
Another pricier option is the Baldwin seat. Also gets rave reviews on this site. http://www.motorbikesaddles.com/Kawa...ys%20Seats.htm
A third option would be to mod the seat yourself. Add a bit of foam to the front of the seat to raise it. Perhaps cut some foam away from the back of where you sit to lower it. Wondergel makes a gel pad with small pillars (I think it is called collapsible pillar) which are supposed to be very comfortable plus absorbs vibration. Smaller pillars are better. This one looks pretty good to me: https://wondergel.com/index.php/seat...-no-cover.html . Another gel pad which has gotten good reviews online is Conformax https://onlygel.com/index.php/motorc...o-set-240.html
Modding the seat oneself looks pretty simple. Use a sharp knife to cut away the factory foam, then install the new gel or foam to the shape you want. Staple the cover back on to the seat pan.
Fly-Sig is offline
post #5 of 22 (permalink) Old 06-28-2015, 09:40 AM
Fly-Sig's Avatar
The problem I've noticed is the forward tilt of the seat. I slide forward sometimes, getting that smashed junk feeling. Also it causes me to lean more into the handlebars, putting more weight onto my arms. Raising the nose of the seat would level it more, (but also raise the seat height a little bit). As a cheap experiment it is probably worth trying. If it works, maybe then go for a seat mod.
Fly-Sig is offline
post #6 of 22 (permalink) Old 06-28-2015, 02:51 PM
Sounds familiar. I'm 5' 10" with a 29" inseam and not much of a butt - it all migrated around to the front of my body!
My current saddle is a Corbin and it suits my backside very well. I can ride several hours before having to stop and then it's usually because of overall stiffness that comes with advanced age.
Though I've not tried one, I've seen several Seat Concepts saddles and they appear very impressive, especially for the cost. If I had it to do over again, I'd most likely go with Seat Concepts.
post #7 of 22 (permalink) Old 06-28-2015, 03:55 PM
I have an Adcox seat that is very good.
post #8 of 22 (permalink) Old 06-28-2015, 05:40 PM
Here we go again. I to don't care for the stock seat. I tried a Sargent's seat first. Didn't like it. Everyone said try a Seat Concepts so I got one and installed it. Much better. Maybe not perfect but I can ride much farther now. The seat was the only thing that I didn't like on the Versys. Other than that the bike dose everything well. O ya, I am 5-10 and 210lbs inseam 30".
870Buz
870buz is offline
post #9 of 22 (permalink) Old 06-28-2015, 07:19 PM
gyork70's Avatar
I have read that spencer seat mods i think the site is something like www.greatdaytoride.com
gyork70 is offline
post #10 of 22 (permalink) Old 06-28-2015, 09:20 PM Thread Starter
870Buz
This sounds like a good way to go (especially since you are the same size as me). How hard was it to install the foam and cover and make it look right?
thekrnl is offline
post #11 of 22 (permalink) Old 06-29-2015, 07:45 AM
It wasn't all that bad to do. I have a compressor so I bought a staple gun and spray on contact cement and went for it. Seat Concepts has a video on line that shows how to do it. I would do it again without even thinking a bought it. First time was a little apprehensive but doable. It was a lot cheaper than the others $169.00 +$20 shipping. Not $429.00 + shipping.
Good luck.
870Buz
870buz is offline
post #12 of 22 (permalink) Old 06-29-2015, 08:34 AM
BKP
BKP's Avatar
I've got the Sargent. 2nd bike I've put a Sargent on, and it's a world of difference.
The upside is, you have 30 days to return it, if it doesn't work for you. But, my idea of a great seat, is one you don't even notice when you ride... which this does. No more sliding into the tank, no more compressed junk, no more sore ass...
It just works...
Ride safe...
Barry
2015 Versys 650 Pearl White
[space holder for farkles...]
BKP is offline
post #13 of 22 (permalink) Old 06-29-2015, 09:28 AM
Laam seat modification. www.laamseats.com
SHNYROQ is offline
post #14 of 22 (permalink) Old 06-29-2015, 10:25 AM
phasechange's Avatar
Good luck.
870Buz
Having just installed the Seat Concepts on my '14 I concur with the ease of installation. Just be sure that you have a pneumatic stapler. I knew that my hand stapler wouldn't work, but I tried an electric one and the seat material just laughed at it. Like many other people, I just got the cheap Harbor Freight pneumatic stapler and it worked great. The only caveat is to take your time and make sure that you've got the stapler AND the seat cover material firmly in place before stapling. I put a couple of staples clear through the cover material, but hey- the holes are under the seat and I'm the only one who knows they're there.
phasechange is offline
post #15 of 22 (permalink) Old 06-29-2015, 11:37 AM Thread Starter
Good luck.
870Buz
Cool, thanks! I think this is the route that I am going to end up taking.
thekrnl is offline
post #16 of 22 (permalink) Old 06-29-2015, 06:21 PM
Can anyone confirm that the Gen 3 2015 Versys shares the same seat/seat pan/fit with the Gen 1 & Gen 2 Vs?
post #17 of 22 (permalink) Old 06-29-2015, 06:28 PM
kawdog's Avatar
If you are 5-10, and the Seat Concepts raises you up a few more inches, either you are wearing 1970 disco heels or Air Jordan's one
kawdog is offline
post #18 of 22 (permalink) Old 06-30-2015, 06:34 AM
The Seat Concepts seat dose not raise you up two inches. They say it is a little higher than stock but I think it is a bought the same as the stock seat. I never felt higher when riding.
870Buz
870buz is offline
post #19 of 22 (permalink) Old 06-30-2015, 09:46 AM
genehil's Avatar
20k+ miles on my 2011 stock seat with an Airhawk pad. 5'8"/30" inseam.
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #20 of 22 (permalink) Old 06-30-2015, 04:07 PM
Timberdog's Avatar
I was lucky to get a used Sargent and I like it a lot. It took some miles before it broke into my butt. If I didn't get this I would have gone with the Seat Concepts. I have an electric stapler that I have used on other seats and it works good if you use it correctly with short staples. I've had to tap a few staples further in if I didn't have what I was stapling backed up firmly.
I spent most of my money on bikes, booze and broads. The rest I wasted.
I'd like to have a bad day, just to see what it feels like.
Timberdog is offline
