engine trouble - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 02-06-2010, 03:39 PM Thread Starter
Guest
engine trouble
can any one help, my versys hasan intermitant fault that leaves my mechanic scratching his head. when im cruising between 4 to 5000 revs the engine will sudenly lose power but not cut out, i then give it some throttle and away it goes. then again it chug if fuel is thr issue than it will be fine the problem is not constant and onboard ECUreads no faults im at a loss any help?
jason is offline
post #2 of 7 (permalink) Old 02-06-2010, 04:58 PM
TPS or fuel filter if still hitting on both cylinders????
jcctx is offline
post #3 of 7 (permalink) Old 02-06-2010, 06:40 PM
Tank vent hose pinched?
Shatrat is offline
post #4 of 7 (permalink) Old 02-07-2010, 03:51 AM
Hi Jason,
Is your idle at 1300 rpm steady? What's your mileage?
Possible cause:
1. Fault spark plugs
2. Faulty ignition coil
3. Dirty fuel injectors
4. Dirty fuel filter
post #5 of 7 (permalink) Old 02-07-2010, 12:02 PM
A coworker of mine purchased a new zx14 and it had a similar problem. It would idle fine but while going through the gears it would pull hard then slow down and do it rather abruptly. They dealer changed some electronic items with no luck. The dealer finally checked the pressure from the fuel pump and that was the problem. The fuel pump was not holding steady pressure, they replaced it and no more problems. Hope this helps.
dreambike is offline
post #6 of 7 (permalink) Old 02-08-2010, 01:22 AM
Possibly a bad fuel pump, a short in the main harness from the main switch, or maybe a cracked/leaking coil-over-plug... What's your mileage?
post #7 of 7 (permalink) Old 02-08-2010, 07:16 AM
Guest
My bike has done the same thing but after hundred miles the fi light stayed on for five mins,fault code eventually showed up the oxygen sensor at fault, explained why it happened intermittently. Turning off the ignition and starting it again cured it temporarily, this ruled out bad petrol pinched hoses etc Hope this helps
Christi is offline
