Saturday Silliness. - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 10-25-2014, 06:46 PM Thread Starter
Time's Avatar
Saturday Silliness.
OR I need a Dope Slap.
I keep a eye on my gas mileage as I learned long ago it can tell you when somethings not quite right with a motor. If it drops you need to find out what's going on.
The last three tank fulls on the Versys as seen a 5-7mpg drop and I've been at a lost as to why.
Well the light came on today, not TOO bright maybe 15 watts! I changed the front sprocket to a 16 tooth when I did the chain. And after reading the post here it causes the odometer to read less than then true miles covered by about small amount and that's where my "Miles" went too!
BUt it's was a great day to ride here almost 75 and sunny, it's been in the low 50s and rainy for a couple of weeks and even the hard core have park the bikes. So you guys in the midwest ride it while you can because winter's on the way.
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #2 of 8 (permalink) Old 10-26-2014, 02:46 AM
beers many To
Did you find that you got to your destination faster as well?
You might also be traveling faster than the indicated speedo speed too... so watch it.
I'm running F16/R46 and My real speed vs indicated is about [email protected] and [email protected] and about [email protected]
Gigitt is offline
post #3 of 8 (permalink) Old 10-26-2014, 07:10 AM
My mileage always drops in the winter. I don't know if it's because they use a different "winter" mix in the gas or if the V stays on choke longer. I do know that my commute is about 25 minutes and when it's cold (or even cool) the bike is still on high idle most of the trip.
ray h is offline
post #4 of 8 (permalink) Old 10-26-2014, 07:19 AM Thread Starter
Time's Avatar
beers many To
I checked it at a Radar Speed Limit sign here, they show the posted limit and have a radar that shows your speed, no ticket is sent! Before it was 33 at a posted 35, now it's 35 at 35. But you have a good point.
Plus I used my Galaxy with a GPS app and it's maybe a 1-2 slower at higher speeds, not enough for the police to worry about, unless you're in a school zone. Anyway I was taught to "Go with the flow" and that's what I do in traffic. On the back roads I mainly just putt along, slow and enjoying the day.
2012 650 Versys
Time is offline
post #5 of 8 (permalink) Old 10-26-2014, 08:05 AM
Saturday Silliness.
I wonder if you water temp is too low and ecu is compensating.
Maybe you need to cover up a small section of your radiator to keep the temp in normal operating range like the trucks do in the winters.
Cooler air is better for economy as that means more dense oxygen rich air per stroke. But if the engine stays cold then the ecu changes it map.
Gigitt is offline
post #6 of 8 (permalink) Old 10-26-2014, 08:06 AM Thread Starter
Time's Avatar
Better yet install a T-Bob.
2012 650 Versys
Time is offline
post #7 of 8 (permalink) Old 10-26-2014, 08:08 AM
Saturday Silliness.
I was editing my post to write that LOL
I don't even live in freezing area and I have a Thermo-Bob.
Gigitt is offline
post #8 of 8 (permalink) Old 10-26-2014, 08:15 AM Thread Starter
Time's Avatar
Does't matter who posted it...it's still true.
I put one on the KLR and it could warm up on the ride in to work when it was in the 30s...all of 1 1/2 miles. Much better for the motor to get to operating temperature for everything from better gas mileage to longer life. The oil flows better and the higher temps boil off any moisture in the oil faster, you should see what the oil in my Buell looked like, big air cooled motors can't get hot enough to boil off the water in real cold temps and the oil ends up looking like Mayo!
Oh I want to say I'm NOT on Wattman,s payroll I just believe in the T-Bob.
2012 650 Versys
Time is offline
