Sylvania Silverstar Ultra - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 10-09-2014, 07:51 AM Thread Starter
I installed a couple of Sylvania Silverstar Ultras in my '12 right after I got the bike new last November. I really like them, the performance is noticeably better than the stock bulbs. They claim about 50% better and I believe it, but . . .
They also claim shorter life and it is much shorter. My lowbeam went out yesterday after about 10,000 miles. This squares with some of the other Silverstars I have used in other motorcycles.
I have found you can get the Silverstar Ultras off ebay for around half price. I just ordered a replacement for the lowbeam for $9.99 shipped so that ain't bad. At Autozone the are over $20/ea.
waltermitty is offline
post #2 of 8 (permalink) Old 10-09-2014, 08:18 AM
jmarleau's Avatar
Interesting. Do you know if there is an LED option that is reasonably priced?
I tried a search of these threads, but only found info on $70 options with integrated cooling fans. (!)
jmarleau is offline
post #3 of 8 (permalink) Old 10-09-2014, 08:26 AM
kohburn's Avatar
there are two main LED options cyclops (with fan) and adventure monster (just heat sink)
both are about 45$
there are threads on advrider dedicated to each.
I've installed a cyclops on my high beam and have been very impressed. thinking about trying an advmonster for the other bulb.
kohburn is offline
post #4 of 8 (permalink) Old 10-09-2014, 05:06 PM
both are about 45$
I spent a fair amount of time on Advrider, lots of experimenting, I couldn't find any postings , searching with headlight replacement or Led replacement.
I am on my second set of Oshram 65W on the low beam, I would think I got 500 plus hours.
My only reason to change is for a 400 lumen gain and 40 watt reduction in power draw.
onewizard is online now
post #5 of 8 (permalink) Old 10-10-2014, 04:20 PM
kevrider's Avatar
how many lumens from the stock hi and lo bulbs?
Seal/CRAZY/misquoted
kevrider is offline
post #6 of 8 (permalink) Old 10-10-2014, 05:03 PM
High and low beams are both the same H7 bulb.
Standard 55W H7 bulb: 1500 lumen, 500 hours
Osram 65W Hyper clear: 2100 lumen bulbs, 500 hours
Osram Night Breaker: 1780 lumen, 340 hours
Osram Silverstar: 1750 lumen, 350 hours
post #7 of 8 (permalink) Old 10-10-2014, 05:08 PM
I used the Osram Night Breakers...Liked them a lot.
post #8 of 8 (permalink) Old 10-13-2014, 01:15 AM
andrewhtf's Avatar
I have the Nightbreakers at Low and Hyper at High.
Still have a spare Hyper which i intend to replace for Low when the NB expires, but i am happy with current setup so i guess i will get another NB for Low.
Just make sure you had adjusted your headlamp to your preferred tilt and pan because if your headlamp is pointed wrong, no amount of bulb change can help.
Current : Maroon 2011.
Up next :
andrewhtf is offline
