Avoid these Bobbins - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 08-28-2014, 09:48 AM Thread Starter
Smiley's Avatar
Avoid these Bobbins
Stay away from aluminum swingarm bobbins. I discovered that the left half of the spool that the stand attaches to had broken and separated somewhere on the road. The gouges on the 3rd photo are from vice grips- I needed to lube the chain so I used vice grips to prevent the bike from falling off the stand.
I went to Sonic Cycle (salvage) in London and got a set of proper steel (used) bobbins for $10. Sure, they are black and don't look real pretty on the swingarm, but who cares?... safety first.
Smiley is offline
post #2 of 8 (permalink) Old 08-28-2014, 07:05 PM
Lours_Polaire's Avatar
And it wasn't the result of a previous crash ou drop ???
I mean, their's not that much weight on those bobin for them to fail like that
Anyway, I will surely check mine this week-end to make sure that they haven't started cracking
Cheers
LOP
Lours_Polaire is offline
post #3 of 8 (permalink) Old 08-28-2014, 08:35 PM Thread Starter
Smiley's Avatar
LOP
No crash, just normal lifting with paddock stand to service the bike. The aluminum spool is not robust enough to bear the weight that pivots on the narrow stand supports. Look at the wear grooves in the second photo. That's where mine broke, at the thin, weakest spot.
Smiley is offline
post #4 of 8 (permalink) Old 08-28-2014, 11:04 PM
Mine are kawasaki blue aluminum, I'm sure that adds about 100 pounds to their weight limit
'18 Versys V1K
'09 Versys 650
Jmason is offline
post #5 of 8 (permalink) Old 10-10-2014, 02:18 AM
Mine are motowerk aluminium I'm sure they are fine
post #6 of 8 (permalink) Old 10-10-2014, 06:48 AM
kohburn's Avatar
it's hard to tell from the low resolution photos but that failure looks like a brittle break from a poor alloy grade casting. all the aluminum spools that I've seen have been machined 6061 which would show more signs of a fracture initially followed by stretching and deformation rather than a clean break.
no reason to be afraid of all aluminum, but definately be wary of cast ones like those.
kohburn is offline
post #7 of 8 (permalink) Old 05-15-2015, 11:44 PM
I've got some cheap Chinesee aluminum swingarm spools as well. The right side is about 1/2 way cut through, but the left is fine. I strongly suspect my Pack Jack is the culprit. I'll be replacing the spools shortly with....?
IBA 12512
Harpeaux is offline
post #8 of 8 (permalink) Old 05-16-2015, 12:47 AM
kawdog's Avatar
Yeah, an aluminum foundry is an art of a manufacturing process, so you can throw that out the window in China. I have a $10 pearl gold set on my rear just for my shop's use. I should go ahead and replace them, but they look a hell of a lot better than those that are cracked. It looks like using a steel jack and cheesy Chinese cast bobbins are not the ticket. The T-rex spools are about $50 shipped each: about 1/4 of many retail sliders.
Thanks for the pics, since it reminded me of never getting Chinese cast AL safety parts. I've got a centerstand, but I don't want an accident at the shop because I was negligent (and knew better too.) I'll probably let the shop have them if they sign a waiver that I'm no liable for the Chinese cast al items
kawdog is offline
