Headlight bulb - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 08-12-2014, 07:01 AM Thread Starter
Headlight bulb
Need to replace my low beam bulb, anyone know if this is available from an auto parts store? I am at work and didn't have time to pull the old one. Would like to pick one up on the way home if possible.
WindWalker is offline
post #2 of 8 (permalink) Old 08-12-2014, 07:04 AM
Probably. Which auto parts store can you go to?
post #3 of 8 (permalink) Old 08-12-2014, 07:25 AM
El Tig's Avatar
If you have an autozone, advanced autoparts, walmart or home depot you should be able to get one.
http://www.homedepot.com/p/Sylvania-...FSMV7AodYiIA3w
El Tig is offline
post #4 of 8 (permalink) Old 08-12-2014, 07:49 AM Thread Starter
post #5 of 8 (permalink) Old 08-12-2014, 07:54 AM
Any H7 bulb will work but I like those Silverstar Ultras, a big improvement over stock.
waltermitty is offline
post #6 of 8 (permalink) Old 08-12-2014, 10:50 AM
Freerydejunky's Avatar
65watt OSRAM is the way to go.
Hooligan
Freerydejunky is offline
post #7 of 8 (permalink) Old 08-16-2014, 03:16 PM
Check your H7 bulb before buying, mine went out, bought a PIAA H7 from the dealer, spread of the prongs is wrong, had to make a second trip with the old one to make sure I get the correct one.
'09 Candy Plasma Blue Versys 650 (the fastest color)
Givi DS 450 Windshield
SW motech engine guards
HT Teton Panniers
Acerbis handguards
Avon Distanzia tires
Garmin Zumo 665
dual power usb/12v plug
Givi trunk on custom mount
colodak is offline
post #8 of 8 (permalink) Old 08-16-2014, 04:34 PM
Not sure if you realise, but you can take your high beam bulb, which is the same and use it for low beam, I would personally get a Oshram 65 watt, which I have been running for 4 years now, same 500 hour rating, lots of links on this web site, just got 2 for around $18 total, which included shipping, so $9 each, OEM is 1500 lumens , Oshram is 2000 lumens, huge difference.
