hollow axle - Kawasaki Versys Forum
 3Likes
  • 1 Post By onewizard
  • 1 Post By kitesurfer
  • 1 Post By Smiley
post #1 of 16 (permalink) Old 12-05-2009, 02:37 PM Thread Starter
hollow axle
does anybody know if there is a hollow rear axle available for the V I'm considering buying or building a small trailer and this seems to be the easiest way to go.
mack64 is offline
post #2 of 16 (permalink) Old 12-06-2009, 07:50 PM
No hollow axle available... It would have to be of larger diameter.
There is however a large hollow frame tube under the plastic frame covers. It can also be used for a frame lift:
post #3 of 16 (permalink) Old 05-19-2016, 05:26 PM
chid's Avatar
I will re-use this topic with the same question, but for Versys 650 2015.
Is there a hollow axle?
Versys 2015 Green
chid is offline
post #4 of 16 (permalink) Old 05-20-2016, 07:04 AM
The front axle is hollow.
The rear axle is solid.
As invader said, there is a hollow pipe passing through the frame about six inches above the swing arm mount, under the plastic cover.
IAMRA is offline
post #5 of 16 (permalink) Old 05-20-2016, 08:07 AM
Hollow in frame circled in red. 2015 is the same.
IAMRA is offline
post #6 of 16 (permalink) Old 05-21-2016, 10:52 AM
kitesurfer's Avatar
my 2015 V1000 has a hollow axle. My last bike, a 2013 Concourse had a hollow axle and I pulled a one wheel trailer with it. Home Never an issue with a rode going through the axle.
US NAVY retired
kitesurfer is offline
post #7 of 16 (permalink) Old 05-21-2016, 07:14 PM
Don't need a hollow axle
Not sure what you are looking at but the single wheel trailer uses existing spools on either side, the same ones used for a pit stand.
invader likes this.
post #8 of 16 (permalink) Old 05-21-2016, 10:02 PM
chid's Avatar
I want to install some wheel pods.
it would be much easier to install if I find a hollow axle for the rear.
I find Versys lacks side visibility.
Thanks guys for the answers, maybe I'll find that axle soon...
Versys 2015 Green
chid is offline
post #9 of 16 (permalink) Old 05-22-2016, 12:19 AM
Just take your axle to a machine shop and have it bored out.
post #10 of 16 (permalink) Old 05-22-2016, 05:39 AM
kitesurfer's Avatar
on mine, there was a spool on each end of the rod that passed through the hollow axle. the rod was two piece and screwed together.
Smiley likes this.
US NAVY retired
post #11 of 16 (permalink) Old 05-22-2016, 06:47 AM
Smiley's Avatar
I know the owner of Third Wheel trailers (they are minutes away from here) and he told me the V would have to have a hollow axle, as do all of their single wheel trailers. One could be fabricated, but very expensive. Whether on not our existing axles could be bored out would depend on the type of steel it is made of, and that decision would rest with the owner. A metallurgist should be consulted before making that decision. I don't blame him considering out litigious society.
By the way, if you are in this area they also mount and balance tires. They sell them too, but will install them even if you bought elsewhere. Really good people to deal with.
Smiley is offline
post #12 of 16 (permalink) Old 05-22-2016, 03:35 PM
chid's Avatar
I'm a mechanical engineer and I know that the actual axle cannot be bore out for multiple reasons...
I would look for a specially made one, or from another bike if anybody knows one, but not very expensive...
what are the dimensions for Verys? (length, diameter, thread length, thread)
Versys 2015 Green
chid is offline
post #13 of 16 (permalink) Old 05-22-2016, 08:27 PM
chid's Avatar
It can be bored with great effort... but why???
stress wise, it was made to be full material, if you drill it, you reduce the area that's capable of taking the load.
it is long and small diameter (compared to the length), so hard to keep your tool straight, it will bend in the hole, so your walls won't be equal...
it will be expensive for nothing...
yes, I'm looking for an hollow axle to "borrow" from another bike, eventually... it was more a curiosity..
Dave, do you know something that can replace the original on Versys?
Versys 2015 Green
chid is offline
post #14 of 16 (permalink) Old 05-22-2016, 09:11 PM
chid's Avatar
Yeap, I was looking to build something that goes behind the adjuster blocks, I'll see what's easier.
Thanks for suggestion!
Versys 2015 Green
chid is offline
post #15 of 16 (permalink) Old 05-22-2016, 11:22 PM
post #16 of 16 (permalink) Old 05-23-2016, 08:21 AM
chid's Avatar
auch!! 121 euro.....
no way I'm paying that
I'll look into other options....
thanks guys!
Versys 2015 Green
chid is offline
