GPS power solutions? - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 07-27-2014, 09:49 PM Thread Starter
My current garmin GPS only lasts like 2.5 hours on battery.. any solution for getting it plugged in?
noaim is offline
post #2 of 14 (permalink) Old 07-27-2014, 10:05 PM
BLACK DOG's Avatar
taplite usb cable??
BLACK DOG is offline
post #3 of 14 (permalink) Old 07-27-2014, 10:12 PM Thread Starter
Originally Posted by BLACK DOG View Post
taplite usb cable??
Thanks exactly what I'm looking for!
noaim is offline
post #4 of 14 (permalink) Old 07-28-2014, 12:25 AM
My Garmin auto GPS works reliably in my car, but on the bike, it seems to reboot and power down all on it's own, frequently. I think the issue has to due with the USB connector at the back of the unit and the extra vibration on the bike causing the electrical connection to become flaky. Any suggestions?
I use a motorcycle handle bar mounted 12v and 5v USB connector I bought on ebay. Cost was about $10.
post #5 of 14 (permalink) Old 07-28-2014, 01:57 AM
mikej's Avatar
Try putting some removable adhesive putty around the connector at back of unit. Put connector in, then press adhesive to the connector. This way it is pulling it to the unit.
mikej is offline
post #6 of 14 (permalink) Old 07-28-2014, 04:12 AM
http://www.kawasakiversys.com/forums...462#post159462
post #7 of 14 (permalink) Old 07-28-2014, 06:02 AM
Thanks Cap'n Kirk. I like the reasoning, approach and execution. I will file this for my winter projects.
Richard
rckendall is offline
post #8 of 14 (permalink) Old 07-28-2014, 06:36 AM
Kawasaki makes a assessory plug for the Versys '10 up that includes a plug, relay and bracket that is plug and play but a little pricey. I fits under the left side fairing. You can find them on ebay.
waltermitty is offline
post #9 of 14 (permalink) Old 07-28-2014, 07:55 AM
I chose to hard wire my power cable. Bought the appropriate cable from GPS City and wired it to the battery (with inline fuse of course). Mounted the GPS above the instrument cluster using a Moto Werk universal GPS mount. All I have to remember to do is turn it off when I stop - so far, so good. I've had no problems with intermittent power or random re-booting so I'm pleased with the job. It looks like this.
The other choice, of course, it to take rides less than 2.5 hours. Bad choice!
post #10 of 14 (permalink) Old 07-28-2014, 08:35 AM
BLACK DOG's Avatar
It can be a good choice if you plan on getting lost & using the gps to find home or food
post #11 of 14 (permalink) Old 07-28-2014, 09:42 AM
I usually don't know where I'm going when I leave on a ride, so technically I'm not lost but the food-finding bit is a very good thing whether lost or not. And eventually I usually manage to find my way home. I think my GPS has some sort of "wife getting impatient" feature that activates automatically and takes me home before I find myself in serious trouble. Way to go Garmin.
post #12 of 14 (permalink) Old 07-28-2014, 10:13 AM
I had an intermittent problem with the connection on the GPS - I think it was corrosion from rain. Squirted a little WD-40 on the wire and in the plug hole, and problem fixed.
For power, I just used a cigarette lighter power-plug connected to my fuze-box. Plugged the garmin gps in, and it's ready to go. Power comes on when engine starts. Goes off when engine turned off. Never a problem.
ScottyNeal is offline
post #13 of 14 (permalink) Old 07-28-2014, 10:21 AM
BLACK DOG's Avatar
My wife has come to grips with the fact that when I'm on the bike that I am someplace that I will not be reached at or located, unless that is my desire. She trusts me to be generaly good & to remember where I'm needed.
post #14 of 14 (permalink) Old 07-28-2014, 11:39 AM
I wired mine into the wires for the DRLs beside the headlight - that way it's powered when the ignition is on.
NEVER had my Garmins do that. My present set-up is on Madstad brackets w/ RAM mount pieces to the Garmin mount (Nuvi 550), and they've worked fine for MANY miles, many hours.
