Does anyone else experience this? - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 07-23-2014, 10:41 AM Thread Starter
jtwodogs's Avatar
I know every bike is different, even within the same make and model.
That being said. I am getting older and I guess my driving style is a by product of that fact. So, most of the time I am pretty conservative in my driving style. I have noticed IMHO that after driving that way for a while my V seems to run a little rougher then normal. Only after I take it out and "Stretch its legs" does it seem to start running smoother.
Is it just my imagination or has anyone else experienced this?
Thanks.
jtwodogs is offline
post #2 of 13 (permalink) Old 07-23-2014, 10:52 AM
Apollo Bleed's Avatar
Do you give the V time to warm up? When I turn mine over she starts in a fast idle and after a few minutes slows down and purrs like a kitten. When I just jump on from a cold start, and go, I do notice she needs a little time before she runs smooth like when I let her warm up.
Apollo Bleed is offline
post #3 of 13 (permalink) Old 07-23-2014, 10:57 AM
Thanks.
I ride 'conservatively' too, but I've NOT noticed it being "rougher".
post #4 of 13 (permalink) Old 07-23-2014, 12:24 PM
I put some Berrymans B12 or Lucas Injector cleaner in the bike about every other fill-up and i no longer have that problem.
post #5 of 13 (permalink) Old 07-23-2014, 01:10 PM
goat12's Avatar
+1 on the Lucasoil. I also like to run her hard after a good warmup every so often. Always feels better after.
goat12 is offline
post #6 of 13 (permalink) Old 07-23-2014, 02:36 PM
genehil's Avatar
I haven't noted anything similar...
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #7 of 13 (permalink) Old 07-23-2014, 09:09 PM
I use a bit of Seafoam once in a while.
redden68 is offline
post #8 of 13 (permalink) Old 07-23-2014, 11:53 PM
2daMax's Avatar
How km/miles on the plugs?
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #9 of 13 (permalink) Old 07-24-2014, 03:12 AM
Yes
Gigitt is offline
post #10 of 13 (permalink) Old 07-24-2014, 05:25 AM
It's called an Italian tune-up.
waltermitty is offline
post #11 of 13 (permalink) Old 07-25-2014, 06:13 AM Thread Starter
jtwodogs's Avatar
Have not checked lately but probable under 7,000 on the bike. It runs fine, don't get me wrong. I guess I am just an obsessive compulsive. When I was in college I had a V twin, they seem to run a little smoother, albeit not as much power as the side-by-side.
jtwodogs is offline
post #12 of 13 (permalink) Old 07-25-2014, 07:34 AM
ggg
ggg's Avatar
Thanks.
its normal, to fix the issue pic a good road and just rev the crap out of it for around 20 mins in the low gears, it will get real hot and burn up the excess carbon , no need to add stuff to fuel etc revs and heat is a cheap fix.
ggg is offline
post #13 of 13 (permalink) Old 07-25-2014, 10:58 AM
Prime95's Avatar
I have found that Seafoam if used consistently in small amounts (maybe a shot or two's worth per tank) keeps the bike running consistently.
When I wintered the bike, I filled up the tank and added nearly half a can, and then did one last ride to rack up 60 or so miles. The bike started better than my car through winter. This season I have been busy with other things and let the Seafoam practice slide.
With that, I normally ride enough that I never have had the rougher running crop up- but this year has been a bad year for tires. Although I've spent hours reading up on the merits of plugs patches and the merits of each- the shop just called me and let me know that my 3rd rear tire has now been installed. It's been a good year for them.
So- the bike has had these intermittent spurts of use, and then sitting, and at this point I think what needs to happen is a can of Seafoam and [finally] putting some good highway miles on.
Prime95 is offline
