How you mounting your Oxford heated grip control box? - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 07-22-2014, 10:44 PM Thread Starter
Anyone here fitted Oxford heated grips on their bike? I just put a set on my Versys because I've used them on other bikes and loved them. Problem is the typical mount bracket they supply does't quite work on the Versys leftside clutch perch due to the mirror mount being in the way.
I wanted to see if anyone else had any slick ways they mounted the control module for the grips?
Michelangelo is offline
post #2 of 6 (permalink) Old 07-23-2014, 12:43 AM
Bend bracket straight?
Gigitt is offline
post #3 of 6 (permalink) Old 07-23-2014, 03:06 AM
on the stock Kawasaki heated grips. they use a longer bolts, a spacers and mounting plate off of the mirror mounting bolts.
a quick search here may have used ubolt
another one off the mirror
Motojunkee is offline
post #4 of 6 (permalink) Old 07-23-2014, 09:05 AM
mikej's Avatar
Here is link to a bracket I made to hold a remote right there. Its Aluminum from Lowes, bent, and "milled" with drill press. Covered in velcro for remote attachment/removal.
mikej is offline
post #5 of 6 (permalink) Old 07-23-2014, 09:53 AM
I just bent the pkatform part of the bracket up a few degrees at a time till it fit on the mirror mount.
08' Versys
HAWKSHOT99 is offline
post #6 of 6 (permalink) Old 07-23-2014, 11:04 AM
lacucaracha's Avatar
The problem for me wasn't the angle so much as the spacers not allowing enough space on the clamp. I just 3M taped mine to the center of my handlebar clamp. It's actually super sturdy and very easy to access.
2014 Versys ABS
lacucaracha is offline
