Motowerk Anti-Vibe Riser - Kawasaki Versys Forum
post #1 of 18 (permalink) Old 07-14-2014, 08:59 PM Thread Starter
KawiKyle's Avatar
Just put one of these on and thought I would do a super mini review.
I have several Motowerk products installed and they are all of highest quality. This piece is really no exception. I bought the anodized black version if you were wondering.
I would put the vibration reduction at somewhere around 30%. I do have stock mirrors on some motowerk extenders and I can at least now get a picture of what is going on behind me instead of the blurry jumble I was getting before.
In actuality, the best feature is just the "riser". It really is a small adjustment towards the rider but I am finding it takes a good riding position and makes it immediately great in my opinion. The bike just feels better overall, especially on corners.
If you really aren't all that bothered with your mirror picture I would spend less money and just buy the riser he offers. Hope this helps someone.
KawiKyle is offline
post #2 of 18 (permalink) Old 07-14-2014, 11:29 PM
eddieglitter's Avatar
Thanks for the review. Very helpful.
Can I just ask which version of the Versys you have.
eddieglitter is offline
post #3 of 18 (permalink) Old 07-15-2014, 06:43 AM
Smiley's Avatar
I wish somebody made one at the stock height. I don't want friggin ape hangers, the stock height is fine. I added a Seat Concepts and just slightly tipped the bar back a bit: perfect.
Smiley is online now
post #4 of 18 (permalink) Old 07-15-2014, 01:37 PM Thread Starter
KawiKyle's Avatar
Originally Posted by eddieglitter View Post
thanks for the review. Very helpful.
Can i just ask which version of the versys you have.
2014 650
KawiKyle is offline
post #5 of 18 (permalink) Old 07-16-2014, 09:27 AM
80-watt Hamster's Avatar
I'd personally like one thats about a half-inch SHORTER. Lookin' for a hair more forward lean. Might start experimenting with bars, if I could figure out which one to try. Can get expensive when you don't get it right the first time. </threadjack>
Jon
'09 Versys in Blue
80-watt Hamster is offline
post #6 of 18 (permalink) Old 07-16-2014, 02:22 PM
goat12's Avatar
Me too! Speedy- You seeing this? I loved the effect of the anti-vibe riser, but the height change ruined the seating position for me. I bet a lot of people would be interested in a non-riser version just to reduce vibes!!
goat12 is offline
post #7 of 18 (permalink) Old 07-16-2014, 04:31 PM Thread Starter
KawiKyle's Avatar
lol, it only pushes it back towards you a little over an inch.
KawiKyle is offline
post #8 of 18 (permalink) Old 07-16-2014, 05:28 PM
Smiley's Avatar
Only an inch eh? An inch higher and back is a lot, and it's too much for me. I sometimes wish I had a lower bar. I could use the anti-vibe if I changed to a lower handlebar, but that is too spendy for me. I'm frugal, not cheap, just don't have much disposable cash.
post #9 of 18 (permalink) Old 07-16-2014, 07:15 PM
panamafrog's Avatar
I'm going to plagiarize myself and copy what I wrote on Speedy's site. "I bought a 25mm Handlebar Riser prior to my first long trip last summer with the idea of trying it out. It worked great for a solo ride from Seattle to Denver and back. Later in the summer, on another trip w/others I found I was more tense & it changed the pressure on my arms & I was less comfortable. I made several adjustment to the bars on the ride with no benefit.
When I returned, I called MotoWerk to ask the possibility of getting a riser of a lesser thickness, or having my riser cut down. We discussed these changes and I placed an order for a new riser with a 17mm thickness. I kept the original one to take along on the next ride in case I needed to make a change on the road or to have it to cut down to a smaller size if necessary.
New riser ordered, and received in record time. It was installed and used on my last long ride of the summer with great results. Speedy is a great guy, Motowerk is a great business, providing excellent products for our m/c?s. - Frog, Seattle"
Reason for posting this here is to show how well Speedy works with the customer. He readily offered to manufacture a thinner riser and was quite helpful in the discussion on my reasons for the change. I don't know just what a minimum thickness would be, but by all means give him an email or a call and ask a question. I'm sure, if he can help, he would be glad to.
Frog
(Chiriqui, Veraguas, Herrera, Los Santos, Cocle, Colon, and Panama provinces of Panama)
panamafrog is offline
post #10 of 18 (permalink) Old 07-16-2014, 07:29 PM
djg
May I suggest Rox brand? They can rotate significantly allowing different bar positions, and can be solid or rubber. I have a pair of rubber ones, I like them. Very well made.
For those not happy with Speedy's. I have Speedy's peg lowering kit and mirror extenders. Top quality, great service.
http://www.revzilla.com/rox-risers
djg is offline
post #11 of 18 (permalink) Old 07-17-2014, 05:17 PM
I have BOTH 2" Rox risers, and I really don't see any difference, vibration-wise (NOT much vibes!). And I TOO have the other stuff from Speedy, like djg.
post #12 of 18 (permalink) Old 07-18-2014, 07:49 AM
Smiley's Avatar
I was thinking (always dangerous) about the vibes from parallel twins, and have wondered why manufacturers haven't taken a similar approach to the old Norton firm. By the time the 750 cc Atlas was developed vibrations had reached an intolerable level (no counterbalance shaft). For the Commando, which had the same engine with more HP, their solution was Isolastic engine mounts. At idle the bike would shake like a paint mixer but once underway it was very smooth. My first Commando was the notorious '72 Combat and it was very good (until they grenaded from bad mainshaft bearings). I put aftermarket adjustable vernier isolastic mounts on it to cure the slight handling woes that developed from the stock mounts, that tended to wear out. The vintage race guys still use them- Herb Becker, the best tuner out there, uses them with only one thou' of clearance, and his bikes are winners.
I experimented a bit and found that if I took off the top head steady mount the bike shook so bad it was almost unrideable.
I wonder if the parallel twin manufacturers have experimented with a similar system? I know the Mk2 V's have a rubber rear mount but by most accounts they are no smoother. Has anybody here had both Mk1 and Mk2. and do you feel that the difference is significant?
Any opinions on the isolastic approach?
post #13 of 18 (permalink) Old 07-18-2014, 12:45 PM
I think that the 'modern' solution - balance shafts - probably gives better results. I know that my Vs do NOT vibrate nearly as much as my old Triumphs did....
post #14 of 18 (permalink) Old 07-19-2014, 08:24 AM
Smiley's Avatar
I agree, but the vibration is still worse than what it could be.
Recently my left mirror, an Aprilia that replaced the OEM that vibrated to death, almost fell out. I had to tape it to get home or I would have lost the glass.
I fixed it by running a bead of silicone around the edge and into the small gap. It now is smoother than the right mirror, which I might give the same treatment too. Regardless, I find that unacceptable. I know that parallel twins are shakers, even with balance shafts, but other manufacturers' are smoother than the V.
post #15 of 18 (permalink) Old 07-20-2014, 09:21 AM
djg
My recently departed '93 TDM850 was noticeably smoother and more refined feeling than my Versys. 850 vertical twin with balance shaft. The bars and pegs on the TDM are both rubber mounted stock. A bike that never caught on in US.
djg is offline
post #16 of 18 (permalink) Old 07-20-2014, 02:31 PM
tmclean's Avatar
I too just installed the Motowerk Anti-vibe Riser on my 2012 Versys and quite happy with it. Last year I had my seat customized by Baldwin Saddles where Baldwin actually sits you further back than the stock Versys seat. Going back an inch or so with the riser makes for a much more comfortable sitting position.
I also have Motowerk's mirror extenders installed where I can now see whats in the mirrors. Just heading out to the garage to install my just arrived front foot peg lowering blocks from Motowerks As usual Motowerks produces a quality product and fast shipping.
As a side note I also installed Grip Buddies, cost $25 which also absorbs some vibration. Huge difference in the feel and handling. Hard to quantify the remaining vibration in % but would guess less than 10% now.
Here's the website for Grip Buddies
http://www.originalbeemerbuddies.com/
tmclean is offline
post #17 of 18 (permalink) Old 07-20-2014, 09:14 PM
My 08 with 40,000 miles is MUCH smoother than the 2013 I just bought. I'm sure once I get some more miles on the 2013 it will smooth out some. It is literally like riding 2 different bikes. I do have the anti-vibe on my 08. Both have 43 rear sprocket.
hk9151 is offline
post #18 of 18 (permalink) Old 07-24-2014, 01:10 PM
DJG, which ROX did you put on your V. After just completing my first 500 mile two day trip, I would like to try some anti vibe risers. With my size (5 - 10) and 32in. inseam on the stock seat, i could have room for an inch or two higher on the bars and bring it back an inch for a natural position without any lean.
rayj
2009 Versys (Mine's Green)
rayj is offline
