Did something stupid - Need help with part numbers - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 07-11-2014, 06:37 PM Thread Starter
OK, so I took the front and rear wheels off to get new rubber mounted.
I think either myself or my kids (I'm blaming the kids) threw out some of the parts.
I've got a 2012 Yellow Versys.
For the left side I've got the cotter pin, axle nut, washer and that rectangular block that you use to adjust the wheel forward / back.
I'm missing the rear axle which I believe is part number 41068-0054.
I'm also missing that rectangular block for the right side. What else is on the right side that I need? The axle will slide through the rectangular block from the right, through the wheel, through the rectangular block and washer on the left and then put the axle nut on.
I have the spacers for the wheels.
What is the part number for the rectangular block?
Is there also a washer for the right hand side?
I believe that I'm only missing the axle itself, the rectangular block and probably a washer for the right side.
Any guidance would be much appreciated.
darryldale is offline
post #2 of 5 (permalink) Old 07-11-2014, 06:39 PM Thread Starter
OK, it would appear that the square block is part # 33040-1109 Adjuster Chain.
Now I just need to know if there is a washer on the right side and if there is anything else I might be missing.
Darryl
post #3 of 5 (permalink) Old 07-11-2014, 06:42 PM Thread Starter
The square piece:
http://www.partzilla.com/parts/searc...ARM/parts.html
The axle itself:
http://www.partzilla.com/parts/searc...HUB/parts.html
There does not appear to be a washer on the right side.
Is that correct?
post #4 of 5 (permalink) Old 07-11-2014, 06:43 PM
http://www.partshark.com/fiche_secti...12&fveh=128566
post #5 of 5 (permalink) Old 07-11-2014, 06:45 PM
I have always googled OEM Yamaha parts and come up with several vendors who have all the parts fiches needed. Give it a try. The diagrams will tell you all you need to know.
Richard
rckendall is offline
