Seat...?? - Kawasaki Versys Forum
post #1 of 34 (permalink) Old 07-06-2014, 04:04 PM Thread Starter
Seat...??
Just went out of the city first time , to see how it behaves on a Hwy.... After 60min. Got a headache ( wind noise) and I realized I will need a better seat .... What would you recommend for comfort - for someone who only rode Touring bikes for years ....??? Corbin?? There was another name mention somewhere here ...????
Thank you,
W.
Watchful is offline
post #2 of 34 (permalink) Old 07-06-2014, 04:45 PM
Thank you,
W.
Corbin on a Versys is a bad idea (They Suck)...
A great all around seat on the Versys is a Seat Concepts. Then if your doing really long rides look into the Russell Day-Long or Baldwin. I went through 7 seats on the V.
post #3 of 34 (permalink) Old 07-06-2014, 04:47 PM
I like the seat, longest day 850 miles.
waltermitty is offline
post #4 of 34 (permalink) Old 07-06-2014, 06:15 PM
V-COASTER's Avatar
earplugs for the wind noise and Seat Concepts for the seat.
2013 Versys1000
V-COASTER is offline
post #5 of 34 (permalink) Old 07-06-2014, 07:10 PM
Terry Adcock seat with an Air Hawk pad= Maximum comfort, for me anyways
post #6 of 34 (permalink) Old 07-06-2014, 11:06 PM Thread Starter
Thanks for the info.
Years ago I ordered a Corbin seat for my cruiser-it arrived as a unit that replaced the stock; The Seat Concept and Russell , provide the cover only ...?? Not sure what to do with that ....??? Remove the stock first ...???
Watchful is offline
post #7 of 34 (permalink) Old 07-06-2014, 11:46 PM
kimel's Avatar
Baldwin fan here. It isn't cheap but it's a great seat.
2009 Kawasaki Versys
kimel is offline
post #8 of 34 (permalink) Old 07-07-2014, 12:41 AM
There is mod posted here about raising the front by adding washers and a spacer to the front bracket. It worked for me and so saved me a bundle....found it, post 27 on the link below details the mod. Easy enough to try this before checking out other options.
http://www.kawasakiversys.com/forums...ht=seat&page=2
david3921 is offline
post #9 of 34 (permalink) Old 07-07-2014, 01:35 AM
Gave mine a little more support under the legs works for me just got back from an 8000 km ride
post #10 of 34 (permalink) Old 07-07-2014, 08:22 AM
For solo riding, the terry Adcox seat is #1.
post #11 of 34 (permalink) Old 07-07-2014, 08:34 AM
Unlike Weljo, I don't believe Corbin sucks. It works for me and has been comfortable for my backside for many miles.
Unfortunately, no one can tell you what will work for your backside, and that makes finding the "right" saddle very difficult. It's almost as difficult as finding the "right" bicycle saddle - and they can be almost expensive as some motorcycle saddles.
Not much help I realize, but there's no silver bullet when it comes to saddles. Ah, if I manufactured a saddle that worked for everyone I could call it "The Sliver Bullet."
post #12 of 34 (permalink) Old 07-07-2014, 08:43 AM
kballowe's Avatar
Getting comfortable on a Versys can be a challenge due to the seat size, if one is comparing to cruiser style bikes.
Mine has the Seat Concepts seat cover/foam. It's substantially more comfortable than the factory seat, and removes the forward slope of the seat. You can send your seat to them and they will install the cover for $20, and you pay shipping both ways. Or, find a local shop to do the work.
Be aware that this option will raise the seat height by at least an inch, maybe a fuzz more.
Wind noise. Yes. I complained about that until everyone said STFU.
I'm 5'9", 34" sleeve, 29" inseam. The wind noise off of the windscreen was horrible. In my case, I installed a Givi D410ST windscreen and it provides a 50% reduction in wind noise. If you're taller - then you're going to need a much larger windscreen.
P.S. I have a Corbin on an FJR1300 and a Super Tenere. They suck until you add an AirHawk seat cushion. Then they suck less.
kballowe is offline
post #13 of 34 (permalink) Old 07-07-2014, 09:34 AM Thread Starter
Thank you all.
So, for the AirHawk, I just slide it over the stock ??
Watchful is offline
post #14 of 34 (permalink) Old 07-07-2014, 10:23 AM
Me too (but NOT quite 850 miles/ day!) - w/ the front raised 9/16".
post #15 of 34 (permalink) Old 07-07-2014, 11:26 AM
kballowe's Avatar
Thank you all.
Yes. I (initially) did that. The problem is that the seat still had too much forward slant. It's possible to shim the seat and remove some of the forward slant, but it wasn't enough for me.
kballowe is offline
post #16 of 34 (permalink) Old 07-07-2014, 02:33 PM
Over the past 6 + years, I have ridden with the stock seat, the Corbin (with and without an Airhawk on it), and the Seat Concepts. I like the Corbin the best.
Like others have said - the SC Seat makes you sit higher. I have found that I sit so much higher with the SC that I get even more wind noise, with turbulence hitting my helmet at about mid forehead. It lifts my head further into the air stream.
The Airhawk on the Corbin helps my rear end on long rides, but it also lifts my head farther into the turbulent air stream.
To keep from getting uncomfortable on long ride, I shift around on my bike frequently, and use both my added "highway pegs", and the passenger pegs, and even use combinations of all peg positions, with different right and left foot placements.
trialsguy is offline
post #17 of 34 (permalink) Old 07-07-2014, 02:59 PM
Remove the staples from the front portion of the stock cover. Starting back 6" from the front, cut the foam to get a comfortable fit for you. I actually removed "all" the foam after 6" to the passenger segment. Check comfort by pulling the cover in place, and just sit on it, to check that the contour is ok. Once done, re-staple the cover in place. Then, put an AirHawk R pad on top. This is a very comfortable solution, and can be adjusted for your height and your butt-contour.
I found this worked best for me after trying many, many different combinations.
ScottyNeal is offline
post #18 of 34 (permalink) Old 07-07-2014, 03:31 PM
And yet mine never had the forward slant people talk about. Like someone said above we are all different
post #19 of 34 (permalink) Old 07-07-2014, 03:37 PM
kballowe's Avatar
So, YOU are THAT guy, the one guy that the seat was designed for !!!
(just kidding)
kballowe is offline
post #20 of 34 (permalink) Old 07-07-2014, 05:22 PM
Lots of suggestions & I'm in agreement with most; the stock seat sux! So here's one more...I went with a Sargent seat. It has a wider platform & I'm not being jammed into the tank. I got the optional red piping that matches the bike's color; looks great & very comfy. It's a bit pricey, but worth it for me.
Also installed the givi screen, which really works well. The airflow now hits the top of my helmet (I'm 5' 10"), just above the face screen. At most speeds, I could ride with the face screen up & not be bothered.
Pongo
~Not all who wander are lost.
Pongo is offline
