Lifting the rear wheel - Kawasaki Versys Forum
Like Tree3Likes
post #1 of 25 (permalink) Old 06-24-2014, 11:24 AM Thread Starter
KLE Donk's Avatar
What do you guys use to lift the rear wheel for tire removal, chain maintenance, etc? Any certain type of rear wheel lift stand?
KLE Donk is offline
post #2 of 25 (permalink) Old 06-24-2014, 11:30 AM
I use a Pitbull stand with Pitbull spools.
waltermitty is offline
post #3 of 25 (permalink) Old 06-24-2014, 11:49 AM
BLACK DOG's Avatar
In order of cost
harbor freight
cycle gear
t rex
pit bull
paddock stands should come with any bike that doesn't have a center stand
BLACK DOG is online now
post #4 of 25 (permalink) Old 06-24-2014, 12:04 PM
El Tig's Avatar
Whichever stand you get you'll need 10mm spools for your swingarm for the stand to catch on.
El Tig is offline
post #5 of 25 (permalink) Old 06-24-2014, 02:14 PM
I have a Harbor-Freight in BC, and a T-Rex in AZ. I also have a T-Rex front stand W/ the front triple-tree adaptor in BOTH BC and AZ.
There's NO question in my mind that the T-Rex is the "class" of the two.
post #6 of 25 (permalink) Old 06-24-2014, 06:44 PM
+1. They are rock solid and will outlive me and all my bikes.
post #7 of 25 (permalink) Old 06-24-2014, 07:18 PM
For cleaning the rims and chain, I use a Rollastand. http://www.hardlineproducts.com/prod...ollastand.html
ZX6RTraded is offline
post #8 of 25 (permalink) Old 06-24-2014, 07:29 PM
3/8 cold roll rod about 13" and a half circle welded on the end to fit around bolt. Lock front brake, kick stand down, and lift swing arm, put rod from ground to bolt!
Five seconds and done!
Cost $0.07
Kyle E likes this.
post #9 of 25 (permalink) Old 06-24-2014, 07:48 PM
Trail jack.
post #10 of 25 (permalink) Old 06-24-2014, 08:45 PM
As with typical forum responses... each response is the only one you should do.
It all depends on where you are going to do the maintenance.
Side of the road - trail jack
Garage - Rear Paddock Stand - get a sturdy one, not a cheap Chinese built one from ebay.
Cheaper ones tend to move a bit and twist under the weight.
I bought an Anderson Stand - Aussie Built and love the 100mm rollerblade wheels - very smooth to roll the bike around.
Get rear spools/bobbins for lifting, some are chunky and also act as frame sliders protecting your swing arm in a slide.
Gigitt is offline
post #11 of 25 (permalink) Old 06-24-2014, 11:42 PM
Example:
I've used Pitbull stands (they ARE nice, and probably worth the money considering you'll probably never have to buy another rear stand) but I own a Cyclgear stand (I got mine for $34.99 on sale) and it's never been a problem. Come to think about it, I doubt I'll ever have to replace this one either.
cyclesarge is offline
post #12 of 25 (permalink) Old 06-25-2014, 11:28 AM Thread Starter
KLE Donk's Avatar
Thanks for all the responses!
KLE Donk is offline
post #13 of 25 (permalink) Old 06-25-2014, 11:29 AM
My bike came with spools and I bought a Pitbull stand. They're excellent.
TR Versys is offline
post #14 of 25 (permalink) Old 06-29-2014, 11:46 AM
Spools are nice, but not necessary. You can buy stands that lift under the swingarm.
My Redline stand has attachments for spool & for swingarm.
Like when I bought it, I have one bike with spools and one without--different bikes now though.
The most convenient is a centerstand. Not an easy option for our bikes though.
davidg is offline
post #15 of 25 (permalink) Old 06-29-2014, 01:31 PM
As stated before a paddock stand is ideal in your garage, I have a Pack Jack for roadside repairs and chain lubing.
post #16 of 25 (permalink) Old 06-29-2014, 02:07 PM
As stated before a paddock stand is ideal in your garage, I have a (home-made) Pack Jack for roadside repairs and chain lubing.
Me TOO!
post #17 of 25 (permalink) Old 06-29-2014, 03:31 PM
Me TOO!
Great minds think alike....
post #18 of 25 (permalink) Old 06-29-2014, 06:24 PM
angst's Avatar
Ditto!
Cheers!
angst is offline
post #19 of 25 (permalink) Old 06-29-2014, 09:15 PM
I would avoid the cheapest stand you can find. My first purchase was this one and it bent out of shape after some use. It also was frequently going out of width adjustment. Look for a heavily constructed stand and the bike will be more secure on it and it will last. PitBull stands are really well made but over priced. Lots of cheaper alternatives that are still robust.
Type to avoid....
post #20 of 25 (permalink) Old 06-30-2014, 07:35 AM
If you have ABS you HAVE to use spools, as the ABS sensor cable goes under the swing arm on the RHS. The cable is in the way and will be crushed if you use a pad lift.
cyclejohn and tommyvous59 like this.
Gigitt is offline
