Drop Engine to Adjust Valves? - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 03-16-2008, 12:54 PM Thread Starter
I was reading several reviews on the Versys, and noticed in the photos that the valve cover seems almost entirely boxed in by the frame.
Do you have to drop the motor to do a routine valve check or adjustment?
thanks,
Marty
funkychateau is offline
post #2 of 9 (permalink) Old 03-29-2008, 05:20 AM
No... You only need to remove fuel tank, air cleaner housing, air suction valve, stick coils, throttle cables, inlet pressure sensor hose and baffle plate to have full access to the valve cover.
post #3 of 9 (permalink) Old 04-15-2008, 12:21 PM
Thunderbox's Avatar
That sounds so simple. lol
What is the interval for adjustment?
Thunderbox is offline
post #4 of 9 (permalink) Old 04-15-2008, 05:37 PM
Once every 24000 Kms (15000 miles). Inlet 0.15 - 0.21 mm (0.0059 - 0.0083 in.), exhaust 0.22 - 0.31 mm (0.0087 - 0.0122 in.) cold.
post #5 of 9 (permalink) Old 04-15-2008, 05:40 PM
Thunderbox's Avatar
Why do the valves have to be adjusted more often in Canada?
post #6 of 9 (permalink) Old 04-15-2008, 06:07 PM
It's in the service manual, but nobody really knows why. Some USA owners actually have 24000 (15000 miles) specified in their owner's manual. Some have found valves out of adjustment by 24000 Kms; http://www.ninja650.com/phpbb/viewto...valve+interval
http://www.ninja650.com/phpbb/viewto...ighlight=valve
post #7 of 9 (permalink) Old 04-16-2008, 09:24 AM
Thunderbox's Avatar
I'll just check mine at 1000 Kms, then at every 12000 Kms/2 years, just for the hell of it...
12000kms or every 2 years. You need to get on that machine and ride. 6k a year just doesn't cut it.
Have a great summer.
post #8 of 9 (permalink) Old 11-17-2008, 08:41 PM
markaustin's Avatar
This is an old thread, but you guys might be interested to know the mechanic at my Kawi dealer says, so far, the inspections they've done have indicated no nead for adjustment. This is a truly great little motor. Put really good synthetic oil in it and go, baby.
markaustin is offline
post #9 of 9 (permalink) Old 11-18-2008, 07:29 PM
amir_zwara's Avatar
That's good to know!
amir_zwara is offline
Similar Threads
Versys valve adjust fasteddiecopeman Technical Discussion - V-650 22 06-09-2011 02:49 PM
engine revving in 1st Carbo General Discussions - V-650 21 03-22-2010 09:58 PM
Best Engine guard? johnnail Modifications - Cosmetic - V-650 15 10-23-2008 10:09 AM
How to Adjust your Bike just for your style dstarman Technical Discussion - V-650 0 05-03-2008 10:54 PM
How to Maintain and Adjust Your MC chain dstarman Technical Discussion - V-650 0 05-03-2008 03:22 PM
