Will Kappa V33/V35 sidecases work on GIVI mounts? - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 05-29-2014, 05:29 PM Thread Starter
No one (Givi, Kappa or distributers) can give me a straight answer on this. Can some in fact who knows, tell me if the Kappa bags will mount on GIVI side case mounts?
The Kappas look to be the same as the Givi bags mounts.
Michelangelo is offline
post #2 of 8 (permalink) Old 05-29-2014, 06:31 PM
Mac-man's Avatar
Yes.
Kappa cases are givi plx rack compatible.
(Just bought a used set of k33s with a givi plx rack)
Luck favors the prepared.
Mac-man is offline
post #3 of 8 (permalink) Old 05-29-2014, 07:24 PM
djg
Note that is the PLX racks advertised for V35 bags only. Different than the PL racks that fit every other Givi Monokey bag.
djg is offline
post #4 of 8 (permalink) Old 05-29-2014, 10:24 PM
aka Yamadog's Avatar
Kappa K33N (cheap version of the Givi V35)
Givi V35
Both mount on PLX racks
I'm no diplomat
aka Yamadog is offline
post #5 of 8 (permalink) Old 05-30-2014, 03:23 PM Thread Starter
What's the diff then, between the PL and PLX mounts?
post #6 of 8 (permalink) Old 05-30-2014, 05:00 PM
PL racks are used to mount straight-sided bags like the Givi E21's You will need the PLX racks for the Kappa V33's as you can see, I've had both on my bike. Both PL and PLX require rear turn signal relocation. The PL turn signal relocation also require lengthening the left rear turn signal wiring as they are moved even higher and a little further to the rear.
Pic below is a PLX It curves inward giving the V35's (and V33's from Kappa) space for those 35 liters
Pic below is a PL straight sided ...for the E21's and other straight sided bags
I'm no diplomat
post #7 of 8 (permalink) Old 06-01-2014, 04:45 PM Thread Starter
Go it and thanks for the pics. To re-state, I will need PLX for Kappa V33/35 bags.
PLX: curved side mount bags.
PL: straight side mount bags.
post #8 of 8 (permalink) Old 06-01-2014, 06:34 PM
DaveC's Avatar
Correct!
Dave C
2008 Versys (Red)
DaveC is offline
