Siphon oil change - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 10-18-2009, 05:18 PM Thread Starter
Siphon oil change
i was looking at oil in walmart while waiting for them to change my oil (Car)
and i noticed several siphons that showed you how to change oil through dipstick tube. you do not have to touch the drain bolt.
Can you do this with the versys and will it work.You still have to change the oil filter
southbark is offline
post #2 of 7 (permalink) Old 10-18-2009, 06:30 PM
you can do it but you lose the benefits of draining any sludge or metal shavings from the bottom of the pan...running an engine till hot, letting it fully drain to the oil pan then pulling the drain plug really helps to clear the motor of debris
tsunamichop007 is offline
post #3 of 7 (permalink) Old 10-18-2009, 08:25 PM
spiderman's Avatar
Yeah, I suppose you could do it but I don't know why you would want to. You can do a more complete change with the conventional method.
Jeff in Illinois
07 Bandit
03 KLR
82 Rokon
spiderman is offline
post #4 of 7 (permalink) Old 10-18-2009, 09:56 PM
And its not that hard. If it were a bitch to get to, I could understand...
post #5 of 7 (permalink) Old 10-18-2009, 10:05 PM
I dont think you can, not sure, the clucth is near, you may not be able to get the tubing all the way in to the pan, a lot easier to do the old fashion way.
kallkrish is offline
post #6 of 7 (permalink) Old 10-18-2009, 11:49 PM
if6was9's Avatar
What's the advantage? Seems like turning a wrench would be easier; you still need to change the filter.
"I read somewhere that 77 per cent of all the mentally ill live in poverty. Actually, I'm more intrigued by the 23 per cent who are apparently doing quite well for themselves." -- Jerry Garcia
if6was9 is offline
post #7 of 7 (permalink) Old 10-19-2009, 11:27 PM
Hi Southbark,
The Guys are right. Best to drain from the bottom to get all the muck out.
Cheers.
