Red Line Water wetter - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 10-03-2009, 04:01 AM Thread Starter
I wanted to know if anyone had used red line water wetter in there versys.I got a free case from a friend and wanted to know if it really worked and what it does
southbark is offline
post #2 of 14 (permalink) Old 10-03-2009, 11:28 AM
Till recently I was a hot rodder. "Water Wetter" is recommended by most for their rods as very effective, so I plan to use it in my "V" when I drain the coolant.
post #3 of 14 (permalink) Old 10-04-2009, 07:20 PM
Thats odd, any mechanic i know that works on cars says that Red Line stuff rtots the radiator and they all suggest Royal Purples stuff.
mcampana is offline
post #4 of 14 (permalink) Old 10-05-2009, 11:57 AM
I have no idea why anyone would spend money on that stuff. Prestone mixed 50/50 with distilled water works just fine, and it's all I ever use.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #5 of 14 (permalink) Old 10-05-2009, 12:16 PM
FJS
Guest
It is a product that is designed for road racing as they are not allowed to use Ethylene Glycol and mixed only with water. Can be added to EG mixes as well to improve cooling.
FJS is offline
post #6 of 14 (permalink) Old 10-05-2009, 06:34 PM
I'm aware of the road racing use. I can't see using it in a street application in a bike that doesn't overheat as it is. Stock machines don't really have cooling problems. To me, it's a waste of money. I've owned liquid cooled bikes since 1985, and they've all performed very well with conventional coolant that's changed regularly.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #7 of 14 (permalink) Old 10-06-2009, 11:53 AM
What 'Water Wetter' does, is change the surface tension in your water/ antifreeze mixture. As the engine heats up the water's surface moves slightly away from the 'hot' metal, so you end up with a metal-gas-water interface IN SOME AREAS, and that's much less of a conductor compared with a metal-water interface. So 'Water Wetter' will reduce the temps in your engine (I think they claim by 20F).
post #8 of 14 (permalink) Old 11-01-2011, 03:11 AM
Amsoil new coolant compared with Red Line's water wetter.
http://www.amsoil.com/StoreFront/rdcb.aspx
Didn't know Amsoil also had a break-in engine oil:
http://www.amsoil.com/storefront/brk.aspx
This all is just FYI, for what's it's worth
post #9 of 14 (permalink) Old 11-01-2011, 02:29 PM
Darn it! Just when I figured out what kind of oil to use! lol
NDTransplant is offline
post #10 of 14 (permalink) Old 11-01-2011, 11:42 PM
2daMax's Avatar
I wonder how long the RLWW can last before it needs to be changed and I can't find any literature on it. If it is used for racing, it is common to get replacements after the race so that new fluids are in for the next race.
I am hearing about Engine Ice, and Motul MoCool losing its ability to cool better than stock EG coolants after a few thousand kms. It all ends up having the same cooling efficiency as EG in the end. Hoping to hear feedbacks for these enhance cooling users.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #11 of 14 (permalink) Old 11-02-2011, 10:46 AM
I'm glad you got it for free, because on your street bike it's not worth anything else.
dct73 is offline
post #12 of 14 (permalink) Old 11-02-2011, 10:58 AM
We've gone round and round on cooling systems here, and the problem is that it's useless arguing with someone who doesn't understand anything about cooling system design and operation. The best that can be said is that the snake oil probably won't hurt anything other than their pocketbook.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #13 of 14 (permalink) Old 11-02-2011, 12:18 PM
michael95453's Avatar
I used WW in my Triumphs for many years, initially because of track use. I basically never changed it unless I had some reason to open up the cooling system. My Triumphs are still running strong with about 150K miles between the 2 of them. I've also used it in my KLR650, but not my Versys (yet).
I believe WW does not offer freeze protection, so shouldn't be used in colder climates.
Michael
michael95453 is offline
post #14 of 14 (permalink) Old 11-02-2011, 04:54 PM
Water wetter was invented because it does everything coolant does (except protect against freezing) but does not leave a slippery surface on the track like colant if you crash.
As long as you live in an area where palm trees grow or keep you bike in a heated garage you are fine with water wetter, otherwise use coolant instead.
