3.25" oil filter ? - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 09-17-2009, 11:22 PM Thread Starter
glowcat13's Avatar
3.25" oil filter ?
The manual says the engine takes 2 quarts of oil with the filter change that would be with the stock 2.5" filter, does anyone know how much oil I should use if I go with the 3.25" pure 1 purolator or supertech filter. I am due for an oil change and from what I have read going with the longer filter sounds like A good chioce, Thanks.
glowcat13 is offline
post #2 of 8 (permalink) Old 09-17-2009, 11:27 PM
You should just use the sight glass, there are too many variables to count on a volume measurement.
Shatrat is offline
post #3 of 8 (permalink) Old 09-17-2009, 11:43 PM
Keep the bike upright.
Cool engine and see that the oil level is between the low/High mark.
Peace of mind.
post #4 of 8 (permalink) Old 09-17-2009, 11:53 PM Thread Starter
glowcat13's Avatar
Is the sight window accurate with the rear of the bike raised on my swing arm stand?
post #5 of 8 (permalink) Old 09-18-2009, 12:47 AM
Hi Glowcat13,
IMHO, better to have it standing on it's own 2 tyres.
Have someone sit on your bike to do a quick check.
In the service manual 7-8 Engine Lubrication system for oil level inspection it states "Situate the motorcycle so that it is perpendicular to the ground".
post #6 of 8 (permalink) Old 09-18-2009, 01:32 AM
No, it's not accurate. It'll show less oil than there really is because the bike is leaning forward. If you want to do it later on the stand, check it with both wheels on the ground, pick it up on the race stand - make a mark of where the oil level is at that point - now you know what the equivalent level on the stand is to full for future use.
Gustavo
Gustavo is offline
post #7 of 8 (permalink) Old 09-18-2009, 07:00 AM
But two quarts should do it, unless you like to fill it completely to the upper fill line.
post #8 of 8 (permalink) Old 09-18-2009, 07:59 PM Thread Starter
glowcat13's Avatar
Thanks for all the good info, i went with 2 quarts and its fine, I had thought that the extra .75 inches would matter but it didn't make as much of a diference as I thought it might.
