A quick question & answer - Kawasaki Versys Forum
post #1 of 16 (permalink) Old 01-20-2014, 04:15 PM Thread Starter
Banned
Question A quick question & answer
What lube/grease do you use when replacing the back axle after a tyre/tire change?
Britmick is offline
post #2 of 16 (permalink) Old 01-20-2014, 04:25 PM
I keep a tub of Bel-Ray Waterproof Grease on hand for when i lube the clutch cable and when i take off a wheel.
Bel-ray-waterproof-grease by weljo2001, on Flickr
post #3 of 16 (permalink) Old 01-20-2014, 04:28 PM Thread Starter
Banned
I do like a man who keeps a tub of grease handy!!!!!
Seriously, thanks Joe, now does that grease have a high melting point?
Britmick is offline
post #4 of 16 (permalink) Old 01-20-2014, 04:41 PM
http://www.belray.com/sites/default/...us_english.pdf
post #5 of 16 (permalink) Old 01-20-2014, 04:41 PM
+1 for the BelRay stuff weljo posted. I use the same. A tub of that stuff has lasted a dozen years, and I remove the wheels several times a season. I clean the axle and apply a thin coat every time I have the axle out. Never had a problem with a stuck/seized axle.
HondaGalToo is offline
post #6 of 16 (permalink) Old 01-20-2014, 04:43 PM Thread Starter
Banned
Thanks v much to both of you, l'll buy some 2morrow,,,
Britmick is offline
post #7 of 16 (permalink) Old 01-21-2014, 10:57 AM
FWIW - I use Walmart's "Super-Tech" Extreme Pressure, Hi-temp grease. It's red, and I use it for axles, bearings, steering stems, etc.
post #8 of 16 (permalink) Old 01-21-2014, 12:54 PM Thread Starter
Banned
Exclamation
Wow!!!...I can't believe all the technical info that goes with something like a tub of grease, click on the link & scroll down if you don't believe me!!!
Anyway, I wonder if 500'f is safe....really, that axle must get up to some crazy temps when your going at freeway speeds & above on a 100'f day!!!
Auto-ignition temperature 500 F (260 C) estimated
Britmick is offline
post #9 of 16 (permalink) Old 01-21-2014, 12:59 PM
Rode mine 850 miles through the desert in the middle of summer. It didn't catch on fire.
post #10 of 16 (permalink) Old 01-21-2014, 01:00 PM Thread Starter
Banned
Thumbs up
Thanks Ed, the price looks right but I can't find any info on operating temp;s, although l'm sure you've given it a thorough testing!
http://www.walmart.com/ip/Super-Tech...Specifications
Britmick is offline
post #11 of 16 (permalink) Old 01-21-2014, 05:14 PM
Been using this stuff for nearly 25 years. Best out there by far. Wipe some on your garage floor and try to clean up without using some carb spray
ec90t is offline
post #12 of 16 (permalink) Old 01-21-2014, 07:11 PM
G19Tony's Avatar
The shop I go to uses Bel Ray, and that's what I use too.
G19Tony is offline
post #13 of 16 (permalink) Old 01-22-2014, 08:16 AM
Smiley's Avatar
Is that Bel Ray a white (lithium) grease?
I use wheel bearing grease, cheap and nasty, comes in a tube that I bought for probably $3 a decade ago. Have used it on at least 5 of my bikes, same tube, never had a problem. That is the proper application for it.
My Scottish heritage shows, I guess. After all, we did invent copper wire, fighting over a penny.
Smiley is offline
post #14 of 16 (permalink) Old 01-22-2014, 02:04 PM
No, it's a regular hi pressure grease that stays put and won't turn to liquid on a hot day. I use it on everything and nothing shows the first sign of corrosion or squeaking.
ec90t is offline
post #15 of 16 (permalink) Old 01-22-2014, 02:34 PM
...Anyway, I wonder if 500'f is safe....really, that axle must get up to some crazy temps when your going at freeway speeds & above on a 100'f day!!!
You got MAJOR problems IF your axle is getting hot - properly greased bearings (I believe...) would NEVER exceed ambient by many degrees, unless they were failing....
post #16 of 16 (permalink) Old 01-22-2014, 02:57 PM
Smiley's Avatar
I agree. Might be that some people imagine that the axle is spinning when wheel is rolling?
I think that the purpose of the grease on the axle is to facilitate removal and replacement.
Smiley is offline
