Buzzing...from the tail light!?!? - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 07-25-2009, 07:19 AM Thread Starter
furley's Avatar
Hi All,
Just curious if anyone has noticed any buzzing coming from the tail light. I'm not anal enough about to rip it apart and try to fix it, just wondering if anybody else has noticed.
It sounds the same as the dreaded cowl buzz. Oh well, I love the way the engine thumps enough to cause it in the first place!
Now, if I just get a Two Brothers pipe I won't hear any buzzing!
________
Lovely Wendie
furley is offline
post #2 of 4 (permalink) Old 07-25-2009, 03:06 PM
I found the the small rear coloured panels under the seat buzz. The rear plastic push type fixing buttons are a loose fit. You can fix the problem by fitting a suitably sized washer under the button head and refitting. The same problem exists with the rear buttons that fix to the petrol tank and hold the rear of the black instrument cowling. Same solution solves that as well.
zeph is offline
post #3 of 4 (permalink) Old 07-25-2009, 05:16 PM
Yes.
It's a quick fix - both parts. Replace the plastic push-locks on the rear colored trim with small stainless cap-screws and nylock nuts.
The buzzing plastic piece over the rear taillight can be pulled apart with minimal finger pressure. Just shoot a small amount of silicone or permatex around the periphery and push it back together - the rear buzzing all goes away. It also helps keep dirt and mud out of the rear tail light section.
ednukey is offline
post #4 of 4 (permalink) Old 07-26-2009, 09:24 PM
hornet976's Avatar
it's not very hard to fix at all. it first happened to me when i was doing wheelies on mine and i brought the front down a little harder than i would have liked to. anyways all you have to do is take the piece over the tail light off and put two sided tape around the contact areas. i did this and it's not longer a problem.
hornet976 is offline
